Although I see no gas leaks in the gas line and no air leak at the manifold gasket I have to wonder why the Low carb adjust is good at 3/4 turns out but the High is 2 full turns out. unusually high turns, I think. That's why I was thinking air leak. Thoughts? Took carb off and cleaned it. It was spotless. Same problem, bought rebuild kit and all is good. Not sure, all internal parts were looking good and moved as they should. Well, it's back to running good again. It's only 20 years old
I have a yard works trimmer and it does the same thing. To keep it running i have to put the choke at half way on. I took it back to the store where I bought it and they made some phone calls. The outcome is they said the controls are set up for the country where they make it. this country is very high and the atmospheric pressure is a lot different than ours. His advice to me was if I am happy with it working that way just keep it. So far it starts and runs good but it has to be choked all the time half way.
SOURCE: 1976 Gran Torino motorcraft 2150
Are you sure your idle ports ( size of pinhole) in carb aren't plugged with something? What happens if it starts to die, and you give it a quick squirt of WD-40 , down throat of carb?
SOURCE: air leak only idles with choke closed no high speed.
Remove your exhaust manifold. Look into the cylinder with a flash light. You are looking for scratches. Anything larger then a light fingernail is definite proof you need a new cylinder/piston assy.
If it passes that test do the following:
Pour mixed fuel straight into your cylinder until 1/4 full. Slowly pull your saw over while looking into the cylinder. If you see bubbles after the ring/rings go by then you need a new cylinder/piston assy. On rare occasions if no scratches are present on the cylinder wall or piston, you may be able to change just the rings.
SOURCE: Won't idle without choke
The pilot jet controls the air/gas fuel mix at idle . If the jet gets plugged up not enough gas gets to the emgine at idle. You will need to remove the carbs and float bowls and clean them, paying special attention to the pilot valve. Count the number of turns to remove the pilot screw and replace the same number of turns then turn counter clockwise 1/2 turn.
A “very helpful” rating for this answer? Thanks!
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
SOURCE: carb settings poulan 2550 chainsaw, 42cc
Default setting are 1 turn out from in. but chech the metering diaphram as its prob hard..Dont use compressed air to clean
