If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
The error code you gave shows several possibilities for your issue:
Drum charge corona wire, The output of the charge corona wire of the black PCU is abnormal.
Causes
• CGB power pack connection loose, broken defective • Check CGB power pack connection to BCU • CGB power pack defective • BCU defective • Replace OPC drum
Of the five possibilities above, replacing the drum is the most likely cause. Since you only had your drum for a couple of weeks I would take it back to where you purchased it and ask for replacement. Sometimes you get a bad drum out of the box from the manufacturer. It happens. If the same error code pops up again, I recommend you call your local Ricoh dealer for further troubleshooting.
I thinkthesensoryou'retalking aboutis thethermopile.Ifthat iswhatyou mean, shouldgiveanotherdifferent code. Have you sow the fusing exit sensor fan motor (at the front right side of the machine)?
