Watches Logo
Question about The Watches
I have mingrui watch i dont know when we have corrected the time how to save it.
Posted by Jagmohan Dhaliwal on
tip
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC...
How to adjust your Skyhawk for Daylight Savings Time (DST) *aka How to get UTC to reflect the correct time when your local time is set*
According to Citizen's website FAQ, their watches cannot determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. If you are on the winter side of the time change (fall back), you'll have to go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) and in the spring change all of the appropriate timezones back to ON (for summer time). Disappointing, I know... for an otherwise great watch this would be my one complaint.
on Nov 17, 2011 • Citizen Watches
1helpful
I have a Mingrui company sportswatch.But the instuction paper is not fot my watch.It is WR30M
Call the company and see if they will send the paper work you need to your house.
Jan 02, 2013 • Watches
How do i set time on radio controlled wrist watch 3 atm
The point of a radio-controlled watch is that you should not have to move the hands manually. It is meant to respond to a time signal send from various places in the USA, UK, Germany, Japan and (I think) China.
The signal's strength varies considerably, depending on where you are located and the ambient temperature. It may need some application and persistence to get the watch synchronized with the signal, this will cause the hands to move to the correct local time - even then it may need correction if you are in a different UTC time zone or on Daylight Saving Time (DST) locally. Not knowing the make complicates the validity of any information.
I have found that the sync signal is broadcast on the hour for about five minutes and is best received at night where the signal travels further.
Ensure your watch is fully charged and leave your watch by a window overnight for best results.
If you still have difficulty, use an internet search to find the nearest broadcast station to where you are and work out which direction-facing window is best sited to face it.
I have two RC watches - one Citizen and one Casio. One likes to have the left side of the watch facing the window and the other favours the 12 o'clock facing the window, As I don't know the make of your watch I would recommend trying to place it in various orientations until you find one that works for you. I have found the whole set up performs best in cold air situations - and so are more reliable in the winter.
Guessing further, If you bring up the signal display function it may force the watch into signal sync mode - always remembering the 'on the hour' signal broadcasts. You may also find a way of adjusting the hour to suit if it differs for you once it is synced.
5helpful
2answers
How to change the date on a Mingrui WR30m watch and also the day setting unless these are corordinated?
Keep on clicking on mode until it comes up with the seconds flashing. Then click on reset 5 times until the day is flashing. Then click on start until the day changes to the day you want! :D It worked for me
Sep 25, 2011 • Watches
Where can you get english instructions for mingrui watches?
mcdevito75 Here, You can try online, in search from your home page, simply type in the name of your watch plus.com Most watch manufacturers have a website.
Oct 26, 2010 • Watches
6helpful
2answers
Open Questions:
Top The Watches Experts
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a The Watch Expert? Answer questions, earn points and help others
