Question about Binatone Lands Phones
Have binatone 3525 twin. base phone ok, but the hand set seems it is not connected to the base phone.
Posted by Arthur Birkin on
Raj Patel
    Genius:
  • 1,041 Answers
From Manual:
To check whether a handset is registered, make sure mains power to the
base unit is switched on and the handset is within range. The handset's
display should show its number and the <Antenna icon> should be steadily
on. If the display shows
again using the following process:
1. On the base station, press <MENU/OK> and <UP/DOWN> to show
REGISTRATION, and then press <MENU/OK> to put the base station into
registration mode. The base display will show "PLEASE WAIT" and the
base will stay in registration mode for about 2 minute, so the following
handset sequence must be completed within this time.
2. Press <MENU/OK> and <UP/DOWN> to select REGISTRATION.
3. Press <MENU/OK> to display PIN?----.
4. Enter the 4-digit system PIN (default is 0000).
5. Press <MENU/OK> to confirm, and the display will show
PLEASE WAIT flashing.
If the handset registration is successful, the display will change to standby
mode with the new handset number and the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset
number. If the handset registration is unsuccessful, the <antenna icon> will
still flash
Posted on Mar 06, 2019
5 Related Answers
Anonymous
SOURCE: No Link To Base Unit
I am having the same problem!
Posted on Apr 08, 2008
Anonymous
  • 41 Answers
SOURCE: Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Posted on Jan 26, 2009
Anonymous
SOURCE: binatone s1085 skype connection
uploaded driver for this, download it here:
http://www.2shared.com/file/7862486/1e6390e/BinatoneInternetPhone.html
or
http://www.megaupload.com/?d=60BZI5Q5
Unzip it, its a .exe file, that runs direct... (no installation)
either launch it manually
or put it in startmenu>allprograms>startup
other ways to launch files on start up - do a general google search
Posted on Sep 17, 2009
william bennett
  • 945 Answers
SOURCE: No communication from base to handset
http://www.panasonic.com.au/support/downloads/more_info.cfm?objectID=929&fileTypeID=3&productCategoryID=104&productID=754&listQueryString=fileTypeID%3D3%26productCategoryID%3D104%26productID%3D754
Try the above. I agree it needs a reinstallation.
Have patienced things werenot downloading v fast.
Hope i`ve helped.
Posted on Dec 05, 2009
Anonymous
SOURCE: I have twin magicbox vige cordless phones and one
i have the answer for your questions, i have just loaded pictures on my website to do it
Posted on May 21, 2010
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Lands Phones
Please help I can't ring out on my phone
Check for dialing tone by pressing 'Talk On' phone button.
If no tone, check cord at base station and the phone socket is correctly plugged in at both ends using the original cord supplied.
If still no dial tone, check the phone at another phone connection to establish if either the phone or the line is faulty. Address for
Binatone support at this link: http://binatoneglobal.com/support/
Jun 28, 2015 | Binatone Lifestyle 1910 Twin Cordless...
Binatone fusion 2210 - manual
you can download the manual from here as the Binatone website does not seem to hold user manuals http://www.exteradirect.co.uk/download/product/001310/Fusion2200__Fusion2210_UK.pdf
May 05, 2009 | Lands Phones
Power outage messed up my phone
I am sure there is one to download but did not found anything with google... If search engines are of no help, just ask some deep web specialists, e.g. http://manualfox.com - if they don´t find it, it does not exist in the Internet.
Dec 08, 2008 | Motorola Mobility 5.8 GHz Digital Cordless...
I have a binatone g11 cordless phone. I cannot make a call as the handsets keep telling me searching or out of area. Even when i place the phone on the base, it still keep giving me the same message.
Try taking the batteries out of the handset and unplugging the master base set. Leave for 15 minutes and then have a try. This often reprogrammes some handsets to the default mode.
Aug 24, 2008 | Lands Phones
Lands Phones Logo
44 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
