Question about Smeg Refrigerators
What fuse do I need for my Smeg refrigerator? We had a power surge and I need to replace them and the manual mentions European fuse only. Is it the same? Any tips on switching them?
    Top Expert:
  • Smeg Master
  • 66,504 Answers
PROBABLY NOT AS WE DO NOT MENTION AMERICAN FUSES NO DOUBT IT HAS TO BE A 220V FUSE
Posted on Mar 06, 2019
2 Suggested Answers
marked
Mark Gil
  • 6487 Answers
SOURCE: power surge
Yes possibile there's some IC's that are burn inside it and also the power supply can be damage so resetting it will not do anything , if you can take it to a repair center and let them check this unit and fix it.
Good luck........
Posted on Aug 09, 2008
Adrian
  • 109 Answers
SOURCE: I have a Smeg A1 Oven which has lost it's power
The fuse is located behind the rear panel of the cooker. Depending what model this is, it may be an electronic card causing the problem?
Posted on Jun 16, 2009
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
Fuse is blown in circit board
Did you have a power surge recently? That fuse can't blow itself. If a power surge got you then I would say to pull the board and put another fuse in. Of coarse unplug the refrigerator first. This may involve some soldering to remove the caps over the end of the fuse. If you did not experience a power surge then you should probably replace the board. If a component on the board has faulted, then replacing the fuse would be pointless. Because it would just blow it again. Hope this helps.
Mar 24, 2011 | LG 19.7 Cu. Ft. Side-by-Side Refrigerator...
My Smeg S28 has stopped after a power cut last night. The power was down for about 3 hours, and since then the fridge wont come on.
your unit may have experienced a power surge as a result of the power out ask your nabours if they have any electronics in there homes that are not working if so the electricity provider you go with must under law pay for the repair in any case it sounds like in 99 % of cases were power goes out and comes back on with a unit no longer working the power strkie is to balme have the power board tested for damage
best of luck
please remember to rank my reply
Dec 01, 2010 | Smeg FAB28
Apr 02, 2009 | Smeg A1A.1 Gas Kitchen Range
Top hinge has just broken off my smeg fridge.
found an old smeg at the local junk yard and took of the hinges and other parts... cheapest way.
Mar 16, 2009 | Smeg FAB28NE6 Refrigerator With Ice Box
Obtaining a copy of a user manual
NEED USER MANUAL FOR MY SMEG UKFC36RX.ANY IDEAS?
Feb 18, 2008 | Smeg FC36RX Bottom Freezer Refrigerator
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Refrigerators Logo
41 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Mike
Andrew Taylor
Andrew Taylor
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
