Question about Woods Hardware & Accessories
That design has been changed to a more contemporary look >>> more information on following link:
http://waterheatertimer.org/Woods-timers-and-manuals-old.html#59383
The new version is the 50012:
http://waterheatertimer.org/Outdoor-timers.html#50015
Posted on Oct 26, 2019
SOURCE: Where are the pins on
The "pins" are the 48 little tabs that are around the clock dial. That would be 2 in every hour of the 24 hour day.
Push down a pin to start the device that you want to control and pull up the pin at the time you want the device to stop.
Posted on Dec 21, 2010
SOURCE: On my Woods 24 Hour Mechanical Heavy Duty Timer
Switch settings are 'Override' and 'Timer'
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
The manual is unclear which is which.
Pull up a few of the segments located around edge of timer dial.
Segments UP for timer off, segments down for timer ON
Plug timer into wall, and plug lamp into timer.
Lamp is ON and bulb is good.
Move timer switch back and forth to see if lamp turns on.
Manually rotate dial to observe if timer segments are correct for ON-OFF.
Unplug timer and set segments, and rotate dial until current time lines up with black triangle.
Plug timer in.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Posted on Jan 13, 2011
SOURCE: I just bought a Woods
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Woods-59382.pdf
Posted on Jan 23, 2011
Jun 28, 2014 | Woods Outdoor 24 Hour Mechanical Heavy...
Nov 29, 2012 | Woods Outdoor 24 Hour Mechanical Heavy...
Jun 13, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
Mar 13, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
Feb 16, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
Jan 13, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
Dec 08, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Dec 06, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Nov 21, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Dec 15, 2018 | Woods Hardware & Accessories
190 people viewed this question
