Try to hard reset it & then try again for doing this you can:
HardReset.info:
SOURCE: Samsung SGH-D600 "Install error"
you need to reset your phone, that might solve the problem. a full master reset should work.
SOURCE: Cannot access Gmail and orkutb at same time.
I konow all this solutions Please tell me how can i use google chrome for both gmail and orkut at the same time with same id
SOURCE: my gmail app now longer works on phone. I get
update the software to your cell handset, or simply manually go to mail.goggle.com
SOURCE: i cant open or send texts from my samsung star..
I got the same problem. :))
you must reset your phone.
here is the code ..
*2767*3855# but it will delete your contacts and other files. :))
type in address field: http://www.google.com/ig
If
it has not corrected itself by turning the phone off and taking the battery out
for a couple of minutes then turning it back on you should try a factory data reset.
In Idle mode, open the application list and select
Settings - Privacy - Factory
data reset -
Reset phone
-Erase
everything.
