Question about Hitachi Televison & Video
What is the TV code for HITACHI TV Mode # 60EX01BA V0G002017
Posted by Hugh Kopp on
Hitachi dcd combi tv l22dg7u engineer code required to do a factory reset.
You're asking about its 'Service mode key code", I presume.
http://schematicscom.blogspot.com/
http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Please visit these sites to get some details.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 18, 2017 | Hitachi Televison & Video
Tip
Service menu codes hitachi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
RPTVs :
F59 SERIES
* Press and hold the {MENU} button on the TV.
* Then press the {MENU} {8} {SELECT} buttons on the remote.
* To exit, press the {MENU} button on the TV or
the {EXIT} button on the remote control.
DCAM Mode:
* Using the remote control:
* Hold down the {TV} button.
* Press the {MENU} button.
* Press the {INFO} button.
* Release the {TV} button.
* Remote Control Key Functions When In DCAM Mode:
{INPUT} ............. Blue (13x9 adjust)
{ASPECT} ............ ROM Write
{DAY/NIGHT} ......... ROM Read
{MENU} .............. Remove Color
{EXIT} .............. Cross Hatch/Video Mode
{INFO} .............. Green
{GUIDE} ............. Calculation
{2} ................. Cursor UP
{5} ................. Cursor DOWN
{6} ................. Cursor RIGHT
{4} ................. Cursor LEFT
{0} ................. RED (7x5 Adjust)
{STOP} .............. Initialize
{PLAY} .............. Raster Position
{FAST FORWARD} ...... Phase
To Exit The DCAM Mode:
* Press and hold the {TV} button.
* Press the {0} button.
* Press the {1} button.
on Apr 29, 2015 | Hitachi Televison & Video
HitachiC25-F100CRT TV service mode code
Visit this site to get more details. Service mode to different models of Hitachi TVs are not similar. The site linked above have details about service mode to many brand TVs. Pull up older posts there.
Mar 28, 2013 | Hitachi C25-F100 25" TV
Codes for hitachi remote
Hello
Three digit universal remote setup codes for Hitachi TV are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 07, 2012 | Hitachi Televison & Video
I NEED THE REMOTE CODE TO OPERATE A HITACHI TV FROM A PHILIPS UNIVERSAL REMOTE
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
HITACHI ........... 0088/ 0059/ 0142/ 0060/ 0072/ 0004/ 0009/ 0091/ 0001/ 0012/ 0061/ 0137/ 0139/ 0141 /0179 /0227
May 09, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Bpl service menu code
press one time display key and three times mute .service mode will open
Feb 27, 2010 | Hitachi C25-RF35S 25" TV
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I need the code for my tv it,s a hitachi tv so i can setup my philips universal remote control
Hello Jess,
here are the codes for HITACHI .... 002 016 116 216 315 502 507 515 519 607 615 701 707 715 815 902 915
If you not sure how to enter the codes please read on
DVD, etc.).
3. Enter the 3 digit code from the list above . Note:
brand.
Hope this has helped you out. If so then please leave a thumbs up.
Cheers Little Dish Fitter.
Oct 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Need code to program remote to work with Direct TV brand box.
I have the codes you need to set direct handunit for your TV.11145-10145-11960-11904-11445-11345-11045-10797-10583-10577-10413-10409-10279-10227-10173-10151-10097-10095-10056 10038-10032-10016-10105 Switch slide mode to TV make sure tv is on now press and hol MUTE&Select together untill it flashes green now enter code then press power if set turns off that will be your code if not repeat steps untill TV powers OFF.
Jan 10, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
