Question about Pride Mobility Products Health & Beauty
Removing rear wheel pride victory 10 mobility scooter
How do I remove the rear wheels
Posted by Rita zDaniels on
ray gallant
    Top Expert:
  • Pride Mobili... Master
  • 68,282 Answers
5 Related Answers
oregoon
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
oregoon
  • 175 Answers
SOURCE: Having trouble with a 3-wheel Pride Mobility
Check that it is unplugged from the charger. Then check the freewheel lever to ensure it is in gear by placing it out of gear first, then placing it firmly in gear. Do this while the key is OFF. Wait three seconds, then turn back on and it should go.
If it doesn't, and you are sure it's in gear and unplugged from the charger, you should be getting a fault code flashing on the charger display. Consult your owners manual to determine the fault and proceed as recommended.
Here's a link to the owners manual if you've lost yours. Good luck.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Victory_om.pdf
Posted on Jul 11, 2009
Anonymous
SOURCE: Pride Rally 3 Wheeled Electric Mobility Scooter manual
DO not ask FIX IT ALL THEY WANT IS MONEY
Posted on Nov 25, 2009
uxair shah
Muhammad Uzair
  • 812 Answers
SOURCE: I have no manual for my Pride Victory 4 wheel
Hello i hope u 'll be fine.... thanks for using fixya.
You can easily get the manual for Pride Victory 4
Download it and Enjoy
You can also see lots of effective information of your product from this.
  • Manual is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u. Best of luck
Please do rate if it is helpful
THANKS
Posted on Mar 02, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: What is the torque value for the axle nut on the
mcdevito75 here, I would figure 20 lbs.
Posted on Jul 02, 2010
Scooter is saying error code 8 which is motor does anyone know what this could be please?
Pride Mobility Products Victory 9 Scooter 4 Wheel Error code
www.fixya.com > ... > Pride Mobility Products Victory 9 Scooter 4 Wheel
Pride Mobility Products Victory 9 Scooter 4 Wheel, error code related issues. ... Question about Thermometer Mobility Scooters ... error code is 8 Error code 8 means an internal controller error or problem and requires replacement of the controller. ... Theysay there is no listing for code 9 I have replaced the batteries,checked .
Basic Troubleshooting Instructions - Pride Mobility Productswww.pridemobility.com > Resource CenterPride MobilityScooters. INFINFB2040 Sonic Troubleshooting ... Chargers. INFINFB2586 Charger Indicator Codes ... Disclosure Statement Pursuant to Cal. Civ. Code 1714.43(a)[PDF]Legend Owner's Manual - Pride Mobility Products
Nov 28, 2015 | Pride Health & Beauty
Does anyone know where I can find schematics for pride victory?
You need to adjust the tow in. There is adjustment underneath.
Aug 25, 2014 | Pride Mobility Victory 3 Wheel Electric...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Pride mobility victory XL front tyre wear
Is your track rod bent or out of alignment? Carefully buy the exact wheels with tyres and a track rod if necessary from dismantled Victory XL scooters (a good wheel with a good tyre about €30 - I've done that for my Pride Celebrity XL8 - it was a great success.
Jun 03, 2014 | Pride New Mobility Victory XL 4 Wheel...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
Pride victory 10 clicks while going foward
If the click is coming from one side of the rear of the scooter, I would think you have a dry axle. If this is the case, you will hear a regular clicking noise, just as if there is a stone in the tyre. All you have to do is remove the wheel, apply some grease to the axle and re-fit the wheel again. When removing the wheel, be careful not to loose the hub key (usually a small strip of square metal that fits in a groove in the axle and wheel). This clicking noise is a very common problem with Pride scooters and one we regularly deal with, even on brand new scooters. If this doesnt cure your problem there are a number of other things it could be, but i would need more specific details to try and help you. Hopefully its just the axle! Hope I have been of some help to you.
Mar 22, 2010 | Pride Mobility Products Pride Victory 10 -...
Health & Beauty Logo
111 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
