Http://gscs-b2c.lge.com/downloadFile?fileId=KROWM000598807.pdf
Bluetooth® profiles In order to use Bluetooth® wireless technology, devices must be able to interpret certain profiles. This unit is compatible with following profile. A2DP (Advanced Audio Distribution Profile)
Are your devices A2DP compatible? If yes, please comment below with model no. and I'll assist further.
The model is say on add which is LG sound bar NB353OA. Don't know much about this A2DP But if Lg make Bluetooth option why don't want found this device by mobile phone (3 different makes and models), by TV or by laptop. I was read about this and is compatible to share music by Bluetooth from phone or TV. On my soundbar it's show Bluetooth option but any device don't see it. Can't pair. All other functions working fine.
SOURCE: How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
SOURCE: Tom Tom Go 520 can not connect to PC.
I had the same problem with a 750.
I cured it (accidentally I must add) by inserting a memory card.
I guess the last time I connected and disconnected the 750 it had a memory card in and without one inserted it would not recognise the device.
Strange reason but worked for me.
Testimonial: "yes I have since discovered that it will run entirely from the memory card. Flash memory must be corruptrd. Thanks Dave"
SOURCE: the "new device found" screen keeps popping up
Inspect for damaged pin on INPUT 1 socket. (left most of the three HDMI connectors)
A quick pull on the cable can damage the pins.
If you see mis-aligned pins then please power off the set before making corrective action.
Here's a textbook instruction from Mitsubishi
If the New Device Found Screen
Displays No HDMI Control Option
If the New Device Found screen shows no option for
HDMI Control, one of these conditions applies:
• HDMI Control is turned off in the menus of the
new device
Action:
a. Highlight EXIT and press ENTER to close the
New Device Found screen.
b. Display the device's setup menus and enable
the device's CEC capabilities.
c. Wait for the TV's New Device Found screen
to appear again.
d. If the New Device Found screen does not
appear, power off the device. Power on the
device and wait for the New Device Found
screen to display with the HDMI Control
option.
Next time you see the NEW DEVICE FOUND screen pop up.
Toggle the CEC field (on the right side of the pop up) to OFF.
SOURCE: suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
