Question about LG LRSC21935TT 36" Cabinet Depth Side-by-Side Refrigerator w/ 21 Cu. Ft. Capacity, Tall Bottle Dispe...
Where is the water filter on LG fridge LRSC21935TT?
Posted by blair tindall on
geob91
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
Your water filter, if you have one installed, is located in the light housing of the top shelf. It is easiest to take your food off of the top shelf and remove the shelf to get easy access to it. I normally place a towel under it to catch any drips. If you do not see the canister hanging down then the bypass is likely installed. This is not a filter and can be used if no filter is desired. The "change filter" light will go off after a certain amount of time, or usage regardless if the filter,or bypass is installed.
Where is the water filter on LG fridge LRSC21935TT - k0810304-00005-3z3kxnu1glakuzhhdqacfred-1-0.png
Posted on Mar 06, 2019
2 Related Answers
Anonymous
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
Water from the fridge tastes bad
How old are the water lines that run to the fridge? Is this a new fridge? Was the water good and now it is bad all of a sudden or is the first time using the water?
Jun 12, 2012 | LG Refrigerators
Location of water filter on lg fridge freezer
Jul 22, 2009 | Refrigerators
How do i change lg fridge water filter
have just changed the filter on our lg fridge, it's not easy: the filter is external, at the back of the fridge. the fridge has to be pulled away from the wall and then the filter can be seen.
Aug 14, 2008 | LG Refrigerators
I have an LG LSC26905TT side by side fridge
When the filter freezes up, the outside casing may have cracked and will leak water when you dispense water through the door.  You will need to have the filter replaced and that should take care of the problem.  But the filter should never have frozen in the 1st place.  You will need to call a qualified LG technician to see what's going on inside the refrigerator.
May 05, 2008 | LG LRSC-26922 Side by Side Refrigerator
Hi I have just bought a LG GWL227YVQA. All plumb in and the water is from the mains, however after 32 liters of flushing out the system the water still tastes like poo!!! It a new fridge and filter any...
HI,
Tested the water with out the filter and straight from the tap...ok
Tested the water through the fridge without the filter...ok
Tested the water with the filter back on...NOT OK
Problem filter is pants!!!! require new filter.
Apr 07, 2008 | LG Refrigerators
Refrigerators Logo
66 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
