Question about Furniture
52 bottle wine cooler mildew inside need help need help need help need help need help
Posted by Sammy O'Cain on
Jason Hanks
    New Friend:
  • 17 Answers
You are getting too much moisture inside the cabinet. This may sound a little odd, but empty the cooler, put some paper towels down then tip it forward. There's a reservoir behind the back wall that holds excess water and that will drain it out. You want a little matter in the reservoir, but not too much.
Posted on May 02, 2019
Stephen Miller
  • 1,645 Answers
5 Related Answers
Anonymous
SOURCE: U-Line 15WC Wine Cooler Problem
I just had the same problem. Also, I was getting a burning smell. The coil on the unit was blanketed with dust and dog hair. First, I cleaned it all out and tried it. It really didn't do much and I still had the burning smell. I then opened the back and recognized that the fan was not working. Turned out to be really dirty. Cleaned it and no it is working fine.
Posted on Oct 18, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
Anonymous
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Posted on Jun 05, 2009
Anonymous
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Posted on Mar 24, 2010
Anonymous
SOURCE: our lamona wine cooler 300mm is not chilling the
We get the same. Every 10 or so seconds the internal fan kicks in. Called the warranty line whom sent a new fan and an engineer. The engineer said there was no issue with it and checked with the manufactorers. He assured me it was normal and was simply to keep the cool air moving around the bottles to maintain optimum cooling across all the wine. I questions the longevity of the fan due to the constant on off process. He said its a brushless motor fan and simly relies on an electrical current to power it. Ie no actual motor component.
I asked that the help line have this info to hand as it appears to be a normal operational aspect of the unit. I guess lots of people will call the helpline with the same question.
Hope this helps
Posted on Nov 03, 2010
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
What is a compressor based wine cooler?
A compressor based wine cooler is similar to a little refrigerator from the outside and from the inside but it designed to be suitable for wine bottle storage in the exact temperature, in comparison to the other in the market the compressor based wine coolers are much more expensive.
Aug 14, 2012 | Furniture
Hello, I have a problem with some of my labels mildewing and falling off. What should I do to prevent this. I have a 54 bottle glass door cooler
the mildewing is becouse its to damp there and it needs a lot more air to shift this damp away,,,i found the best thing to get rid of mildew is to wash every thing down using a strong mix of white vinegar,,, it works realy well on the inside of wooden boats??
its cheep too, it just smells like a chip shop for a day or so but it will work
Feb 19, 2010 | Danby DWC283BLS Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
U-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Sep 17, 2008 | U-Line 75WC Wine Cooler
Furniture Logo
170 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
