Question about Electrolux Washing Machines
Brand: Electrolux model EWT604 Error code: E3
Abnormal condition of spin-dry
• The safety switch works 3 times continuously.
The number window LED display abnormal code: "E3" and begin blinking on and off at the same time and the electric buzzer sounds to indicate a problem.
Dado
Posted on Jun 15, 2019
SOURCE: RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Posted on Dec 14, 2007
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
Posted on Nov 19, 2008
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
An E3 Error Code means the meter is sensing that blood has already been applied to
the test strip (or the strip has already been used).
What to do: Please make sure you see the flashing blood drop on the display before
adding the blood sample. Ensure that you are using a clean, new strip each time you
perform a test.
