Televison & Video Logo
Nikolas Tollison Posted on Mar 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have Samsung tv UN32EH4300F about 5 years old and the picture is barely visible but sound works fine. What is wrong one of the boards or the led strips?
Jason Schaeffer
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 06, 2019
Jason Schaeffer
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
5637
Points
34
5 years huh. Buy a new TV
JOHN TOPLISS
Level 2:
Habit-Forming:
  • Expert 180 Answers
JOHN TOPLISS
Expert
Level 2:
Habit-Forming:
Answers
180
Questions
Helped
37444
Points
380
It is one or more of the LED strips
5 Related Answers
Anonymous
  • 215 Answers
  • Posted on May 27, 2006
SOURCE: Lost picture and sound
If you're handy enough you could check for a blown fuse. Unplug TV of course. You'll usually find the fuse somewhere near to where the mains voltage cable is soldered into the motherboard. A lot of TVs are fitted with a fuse which is JUST enough to handle the job and after 5 years of continuous on and off that fuse heats up and cools down. Repeat that over the years and the fuse can simply fracture. You'll need a simple ohm meter to check as these fuses may look OK but are open circuit. If the glass in the fuse is black then it's not fatigue and time to call a tech. Make sure you replace the fuse with the same value. BMW
Anonymous
  • 163 Answers
  • Posted on Feb 29, 2008
SOURCE: no picture
Sounds like one of the CCFL's is failing.. (Backlight bulbs).. Some use multiples and others have singular.
Anonymous
  • 240 Answers
  • Posted on Jan 13, 2009
SOURCE: half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Anonymous
  • 44 Answers
  • Posted on Feb 28, 2009
SOURCE: No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
marionbagget
  • 718 Answers
  • Posted on Mar 30, 2009
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Hello. I have a Samsung LED TV approximately 6 years old. One day without warning I had no picture. I performed the flashlight test and discovered that the menu was visible and I had sound. I checked the...
We don't do television repair on this site because it is not possible to do so for the reasons stated here. It would be all guesses. Buy two of every board and mix and match and see what happens.
https://www.fixya.com/support/r29790007-repairing_own_television
My Samsung UN46EH5000F Picture Is Very Dim, What Is Wrong With It?
I will test the back lights first.
To test the back lights, you need to disconnect the cable between the main power supply & the main board, apply the AC power to the power supply, if the back lights are not light up, the back light are defective.
Samsung LN40A540P2FXZA TV turns on, audio works and picture is barely visible, very dark. Is it the backlight?
There could be different reasons for the picture to be barely visible.
I would suggest to visually inspect for swelling/bulging capacitors in the power supply. Try measuring the voltages from the power supply to the main board and backlight inverter boards.
Check the link below to find service parts for your TV.
Search results for LN40A540P2FXZA
1helpful
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
