Question about Panasonic Televison & Video
Why is my microwave door arcing?
Panasonic
Posted by curt mason on
1 Related Answer
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: The microwave model is Kenmore 721.62464201. It's arcing.
This is usually caused by grease or food debris.
First these areas
should be cleaned with a mild, non-ammonia cleaner on a soft cloth. You can use a grille brush if it's stubborn.
Any metal chipped or charred metal will have to be sanded smooth and clean.
Then you should apply some high-temperature appliance paint, available from places like Wal-Mart or Lowe's.
You can find handy exploded views and order any needed parts at the Sears Parts Site.
Posted on Nov 29, 2009
Panasonic microwave model NN-H275: Oven door doesn't open; Makes crackling or arcing sound when turned on;
If you do not see actual arcing in the cavity making the noise it is probably components on the inverter. Too exppensive to repair. Get a new one. Dont like or trust the inverters.
1helpful
NN-CT552 combi. What caused two burn marks On top of the door and on the frame?
The inside of a microwave oven has a special paint on it. If the paint becomes damaged, the microwaves strike the bare metal and arc. This leaves a burn mark. It will also ruin the magnetron inside the oven.
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Arcing and then went dead. Can see arcing from top vent behind fan blade
owwwww! i say,,,owwwww! again.....
its time you dumped this unit,,,to fix it will cost barn nearly as much as a new one
Microwave Panasonic H98
Please check your door safety interlock switches.
When you open the door with the oven running, to check stuff, there is an arc on the tiny contacts. Eventually, they burn and are not able to tell the oven that the door is shut. Forget what you know about the door, the oven has to be sure the door is shut and it uses these little switches for that purpose.
There are other reasons for no heat, this is the most likely one. Check them with a volt/ohm meter. If failed, get replacement from Panasonic, your appliance parts distributor in your town, FixYa.com advertiser, Radio Shack or www.repairclinic.com
Good luck with your repair.
Thanks for your interest in FixYa.com
Panasonic Microwave NNSD277B 5yrs old makes noise after 20sec on (bUzzing and popping)and internal light flashes. Should be replaced or fixed ? what could be the problem?
You should have no arcing within the unit. Assuming you have adequate food/water in the cavity, it should not arc. You NEVER run the unit without something to be heated in it!!!
You might check the stirrer fan which is often in the roof of the unit to see if contamination might be in the area causing arcing. The electric fields in th area are very high and arcs can jump.
If the insulating window is charred or has charred grease, it should bbe replaced.
2answers
Electrical issues inherent in this model?
its the problem of voltage the electriccurrent.call a electrician and get the electricity power checked of your place.the oven is getting required current so this problem is coming.
Microwave does'nt heat up everything else works,just don't heat up
WHAT IS WRONG WITH YOUR MICROWAVE?
small_6_37.jpg For a detailed Microwave illustration, click below.
redarrow.gif Counter top
redarrow.gif Built in
Danger! You can receive a serious electrical shock from the components inside your microwave oven--even when it's unplugged. Only a qualified appliance repair technician should perform any repair.
It doesn't work at all
It sounds normal, but there's no heat
I can't adjust the power level
The carousel won't turn
I have intermittent cooking problems
The display flickers
There's no heat, but it buzzes loudly
It quit after I slammed the door
It looks like there's lightning (arcing) inside my microwave
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Modelnn-h264/s254 1100 watts
This door screen as it's called protects the metal mesh screen from moisture and food debris. The door screen must be replaced or the mesh screen can arc and be damaged, which can lead to microwave leakage. You can order a new screen from Panasonic at: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp It may be this part: F31455H00AP DOOR SCREEN A 5.75 But it might be better to call Panasonic at 800-833-9626 and be sure this is the right part. Be sure to have your FULL model nuber (with suffix) when you call. Be sure to use a cleaner like acetone, etc. to remove all the old adhesive before applying the ne wone, or it will not stick. The door must be squeaky clean and dry.
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
