ENGLISH: Why does the start up repaire appear? Then shutdown restart what needs to be done to remove the startup repaire? I use M73sr neo
Question translated.
We only speak ENGLISH on his North American website.
All questions need FULL 'make model (what it is)' as first three words, and then a proper question, spell check and with CAPS and punctuation in proper English.
This site has no affiliation to the Philippines.
https://translate.google.ca/
SOURCE: BAKIT PO AYAW MAG DERETCHO
Hi
Check first if you can do a self test print on a stand alone not using a computer with out any problem, if its ok then try to reset the spooler by going to the windows services, click on start then run then type in the bos services.msc then look for the print spooler. try to stop and re start, if the problem still exist, uninstall and re install the driver of your printer. if problem still persist then there is a problem on the services of your windows operating system
SOURCE: nagpaper jam po tapos ayaw na magprint my
To solve your problem follow the instruction step by step...
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models).
* While holding the Start/Stop button, press and hold the POWER button.
* When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button).
* Press the Start/Stop button TWICE (still holding the POWER button)
* Release the POWER button.
* Wait for the LCD to display "0? (zero).
Step 2: Using Resetter / Software
Download Ressetter ; http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
* Run "service_tool 1050.exe".
* Confirm detected USB-port numbers on USB port column.
* Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
* Click "platen button" on the "Clear ink counter" section. The printer will print again.
* Turn off the printer and then turn the printer on. You printer is ready for use.
SOURCE: MEMORY FULL
Hi.Don't worry format the phone by typing *#7370# or follow this link Nokia Formating tips.Even if the problem still persist format the E drive too.Good lcuk
SOURCE: bakit po ganun ayaw mag read ng messages ko ..ano po kilanagn gawin
Try spelling out your question with some details then maybe we can help you.
