Cameras Logo
Question about Green Cameras
The green clean light stays on all the time it is on the docking station
Posted by Teresa Sipe on
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
2answers
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
1helpful
How to take Philips docking station out of military time into 12hr format
I think I already answered this but according to reviews I've read of this docking station it stays in military time only...but one reviewer did say that when you sync your phone with it that i will change the time on the docking station to what's on your phone.
Nov 04, 2012 • Cell Phones
5helpful
Camera wont charge
Hi, if you are using the KLIC-5000 battery try to clean the metal contacts on the battery. Try also to remove the battery of your camera dock your camera on the docking station then turn on the camera, if the camera will not turn on it means the charging mechanism of the dock is defective. Now if the camera turns on it means the battery is defective that is why you can charged it.
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
2answers
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
CHARGING LIGHT DOESN'T COME ON WHEN THE DEVICE IS ON THE DOCKING STATION
The adapter that comes with the Archos 605 must be firmly fixed to the docking station by pressing very firmly with a loud click. It feels delicate so if you only click it lightly it wont connect properly. This is poor design but at least it is OK now.
1helpful
Canon Pixma ip3000
the code strip is the plastic strip that runs across the printer and through the head
carriage, it is supported at each end (one end under spring tension).
If it has become dislodged it will cause this problem. carefully try to place it back into place
Top Green Cameras Experts
NOEL
NOEL
Ngoro
Are you a Green Camera Expert? Answer questions, earn points and help others
