Question about Sony PlayStation Portable (PSP) Console
My psp is broken
It automatically goes to the left side of the screen and when you press the button the screen wiggles
Posted by lue102 on
Anonymous
  • 106 Answers
You can try this
take the battery out for 2-3 days (this will reset the PSP) then put it back in.
Posted on Nov 27, 2007
How to connects yhe psp to the internet
  • 1
    On the lower left-hand side of your PSP, you will notice a little silver slider. Slide the switch up and this will turn on the WiFi feature on the PSP. Of course, you do need a home WiFi setup for this to work. Your battery also needs to be full. Even if your battery is low and your unit is plugged in to an outlet, the firmware upgrade may not work.
  • 2
    With a fully charged device, go to your PSP's home screen and choose "Network Update."
  • 3
    This screen will ask you for your WLAN settings. Choose "Scan" and let the PSP detect the network automatically. Choose the right one and keep all of your settings in the default stage. Press the "X" button and the PSP will save the configuration as your new access profile.
  • 4
    Choose it again and when your PSP connects to the network, and if there is an update available, you will automaically see the following message: "Network Update has found a later version. To download, insert a Memory Stick with at least 14MB of free space and press the X button."
  • 5
    Press the "X" button and you should see the message: "Downloading." IMPORTANT - Do not turn off your PSP or remove the memory card during this time!
  • 6
    When the download is finished, you will see the following message: "Download completed. The update is now available on your Memory Stick. To install now, press the x button. To install later, go to [Game]." Press the "X" button to install the new firmware. You may see a few other screens detailing new features to be included in the upgrade, but eventually you will see "Installing."
  • 7
    During the installation, again, do not turn it off or remove the memory card. Once installation is finished, the PSP will tell you to press "X" to restart the PSP. When it powers back up, the new firmware will be in place
  • Read more: How to Upgrade Your PSP Firmware ' eHow.com http://www.ehow.com/how_2288266_upgrade-psp-firmware.html#ixzz1XnkoKCiw
    Sep 13, 2011 | Sony PlayStation Portable (PSP) Console
    I dont how to connect my psp slim to a wireless network connection
    Check that out or follow the below.
  • Turn on your PSP by moving the power button on the right-hand side of the console in an upward motion. Under the console's main screen, go to the "Settings" icon. This is the first icon listed and is farthest to the left. From the drop-down menu, choose the "Network Settings" option at the end of the list.
  • 2
    Select "Infrastructure Mode" and press the "X" button. Select the "New Connection" option to add a wireless connection to your PSP. Choose the "Scan" option to instruct your PSP to search for accessible wireless connections in your area.
  • 3
    Select a wireless connection from the connections your PSP is able to access. Confirm the name of the network and press the right arrow button. Confirm the security encryption settings for the connection. In most cases, the PSP will determine the network's encryption automatically. Enter the wireless connection's password if the network is secured.
  • 4
    Name your new wireless connection so that you will be able to identify it in the future and save your settings. Run a test connection to ensure you are able to connect to the Internet through the wireless network.
  • 5
    Press your PSP's "Home" button at the bottom left-hand side of the console. Move your cursor to the right to find the "Network" icon. Select the "Internet Browser" option from the drop-down menu. Press the up directional arrow and press "X" to enter a web address into the browser. Once you enter a web address, your PSP will automatically connect to the Internet using the WiFi connection you set up previously.
  • if you are satisfied with this response please thumbs up or write a testimonial good luck!
    Jun 01, 2011 | Sony PlayStation Portable Slim Black...
    Got lead to connect psp to pc to download music to psp thought would work automaticly but i go usb mode on psp but cant link them help please
    Hi deanocar,
    Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. If it's not thisis how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
    Jan 18, 2011 | Sony PlayStation Portable (PSP) Console
    I tried to connect to internet from my psp2, but always connection erroe occured. Please advise how to set up wifi connection. Thanks
    Hello
    To connect your PSP to the Internet, you must manually configure the WiFi settings for your device. The PSP will not automatically search for and connect to available wireless
    Nov 14, 2010 | Sony PlayStation Portable (PSP) Slim...
    PSP GAMES
    1. Step 1 On the lower left-hand side of your PSP, you will notice a little silver slider. Slide the switch up and this will turn on the WiFi feature on the PSP. Of course, you do need a home WiFi setup for this to work. Your battery also needs to be full. Even if your battery is low and your unit is plugged in to an outlet, the firmware upgrade may not work.
    2. Step 2 With a fully charged device, go to your PSP's home screen and choose "Network Update."
    3. Step 3 This screen will ask you for your WLAN settings. Choose "Scan" and let the PSP detect the network automatically. Choose the right one and keep all of your settings in the default stage. Press the "X" button and the PSP will save the configuration as your new access profile.
    4. Step 4 Choose it again and when your PSP connects to the network, and if there is an update available, you will automaically see the following message: "Network Update has found a later version. To download, insert a Memory Stick with at least 14MB of free space and press the X button."
    5. Step 5 Press the "X" button and you should see the message: "Downloading." IMPORTANT - Do not turn off your PSP or remove the memory card during this time!
    6. Step 6 When the download is finished, you will see the following message: "Download completed. The update is now available on your Memory Stick. To install now, press the x button. To install later, go to [Game]." Press the "X" button to install the new firmware. You may see a few other screens detailing new features to be included in the upgrade, but eventually you will see "Installing."
    7. Step 7 During the installation, again, do not turn it off or remove the memory card. Once installation is finished, the PSP will tell you to press "X" to restart the PSP. When it powers back up, the new firmware will be in place.
    May 31, 2010 | Rockstar Games Grand Theft Auto: Liberty...
    PSP 3000, screen goes black when the directional
    probably a loose connection and i myself would study it further and then take it apart because thats just what i do i re-soldier stuff thats broken and i enjoy it. but i am not advizing it because as you must know the psp holds power due to sleep mode and can hold sleep mode power for up to 6 weeks and due to this i am in no way stating that you should do this, but if you want to.... i mean ... an engineer would cost £200 just for that so u might aswell fix it or eBay it and then buy a preowned 1 have fun.
    Dec 27, 2009 | Sony PSP-3000 Black Console
    How can i put internet in my psp?
    To connect to the internet;
    1. Check that you have your PSP® (PlayStation® Portable) system set up for Wireless (WLAN) networking in Infrastructure Mode.
    2. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
    3. Make sure you are within range of a wireless access point (or hotspot) that allows connections to the internet.
    4. Select icn_www.gif (WWW) under icn_network.gif (Network) from the home menu and press icn_btnx_color.gif.
    5. Use the up and down buttons to select the address bar and press to display the on-screen keyboard.
    6. Use the on-screen keyboard to enter the address for the web page you want to display.
    7. When you have finished entering the address, highlight the Enter button and press icn_btnx_color.gif.
    8. Select a connection and press icn_btnx_color.gif.
    9. The web page will be displayed.
    10. To hide the on-screen menu, press icn_btntriangle_color.gif.
    Setting up Infrastructure Mode;
    Infrastructure Mode allows you to connect your PSP® (PlayStation® Portable) system to the internet through a wireless network (WLAN) access point.
    Required items:
    • A PSP® with system software version 2.0 or later.
    • A wireless network(WLAN) access point with internet access, such as:
      • A Wi-Fi hotspot (such as those at cafés, hotels and airports).
      • A home wireless network, which might include:
        • A subscription to an Internet Service Provider (ISP)
        • A DSL or cable modem
        • A wireless broadband router
    • Settings used for the SSID, WEP/WPA-PSK encryption and WEP/WPA-PSK key, as specified when the wireless access point was configured.
    To set up Infrastructure Mode on your PSP®:
    1. Make sure the WLAN switch on the left side of the PSP® is turned on so that the PSP® can connect to the internet.
    2. Highlight icn_settings.gif(Settings) from the home menu.
    3. Select icn_networksettings.gif(Network Settings) and press icn_btnx_color.gif.
    4. Select Infrastructure Mode and press icn_btnx_color.gif.
    5. Select New Connection and press icn_btnx_color.gif.
    6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue.
    7. To set the Service Set Identifier (SSID) for the access point, select one of the following:
      • Scan: searches for and then displays a list of access points (or wireless networks) and displays the SSIDs.
      • Enter Manually: allows the user to enter the SSID using the keyboard. Select this option if you know the SSID of the access point.
    8. If you choose the Scan option in the previous step, select the access point to be used and press icn_btnx_color.gif.
    9. Confirm the SSID and press the right directional button.
    10. To enter security information for the access point, choose one of the following:
      • None: does not set security information.
      • Wired Equivalent Privacy (WEP), WPA-PSK (TKIP), WPA-PSK (AES): all set security information. Press the right arrow button to move to the screen for entering WEP or WPA (Wi-Fi Protected Access) keys. Note: The WEP and WPA key fields display eight asterisks no matter how many characters you enter as the key.
    11. After entering the security information, press the right arrow button to continue.
    12. To select the address setting method, choose one of the following:
      • Easy: the following information is automatically set
        • IP address settings: Automatic
        • DNS settings: Automatic
        • Proxy server: Do Not Use
        • Internet browser: Do Not Start
        Note: Most home networks will allow you to use the Easy address setting, which is recommended.
      • Custom: you can manually enter detailed setting information, such as when you are using a static IP network. For details, see the instructions supplied with the network device or the information provided by your ISP.
    13. After selecting the address setting method, press the right arrow button to continue.
    14. Check the settings, using the left arrow button to return to previous screens to make any necessary corrections.
    15. To save the new connection, press icn_btnx_color.gif.
    16. To test the connection, select Test Connection and press icn_btnx_color.gif.
    17. If the connection is successful, information about the network connection will appear. Press icn_btncircle_color.gif to end the connection test.
    You can also check http://www.us.playstation.com/support/psp
    for more information.
    Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
    Internet connection of psp
    6. Use the on-screen keyboard to enter a name for the connection, then press the right arrow button to continue. For more information, see Using the On-screen Keyboard.
    Mar 25, 2008 | Sony PlayStation Portable (PSP) Console
    Where is the aoss button on psp
    The aoss button is not on your psp Its on your stick, hold down the left on your stick. <> It will start blinking. if you dont know what i mean still.There are to lil simbles on your left of the psp They are very small. up just a little bit is a stick.sometime you use the stick to operate your game.(move) Click the left of it. If you dont get that then your ******* stupid
    Mar 18, 2008 | Sony PlayStation Portable (PSP) Console
    Sony PlayStation Portable (PSP) Console Logo
    21 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
    Lee Hodgson
    Lee Hodgson
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
