I cannot open the Parental control because I do not know the Password. How do I proceed?Thanks!
Actually its, 'select' then '7444', and all that does is reset the password.
Press
the SELECT button and enter the 4-digit number "7444" whenever the
Parental Control display asks you for your password. The old password
is deleted.
You will then be prompted to enter a new password, enter
whatever number you want, something like 0000, or a number that is easy
to remember. If you wish to turn it off, just set it to off and forget
about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
Depending on the DVD, you may be asked to change the parental control
level while playing the disc. In this case, enter your password, the
change the level. When you stop playing the DVD, the playback
limitation level returns to the original setting.
After changing DVD settings:
To
save your changes, be sure to eject the DVD before pressing the RESET
button or turning off the unit with the MAIN POWER switch. Please note
that changes will not be saved if you reset or turn off the console
without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
My parental level on the dvd for my honda odyssey stays at level 1 i cant move it up
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
you have changed it to previously, then
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you forget your password, press the following buttons on the remote,
one by one: MUTE, DISPLAY, CLEAR, and RESET (you must be in the
password entry screen). Parental controls will then unlock and you can
re-enter a password via Lock Parental Controls.
If you need the manual please let me know.
