Question about Cooking
Am making Gorgonzola, I have just finished salting the cheeses, then maturing the cheese for 7-10 days. Do I then wrap the cheese in the silver paper and put in fridge or where do I mature the cheese?
Posted by Jenni Hague on
5 Related Answers
Anonymous
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
Anonymous
SOURCE: Rate of interest of post office MIS after three months of maturity.
zxzzzzzzxzxzxzzxzxzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxzzxzxzxzxmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Aug 02, 2008
Joe Hogan
  • 10865 Answers
SOURCE: I have a cheese dispenser from AFP Dispensers,
Hi there. It dispenses nacho cheese sauce.. you can call your local rep. to order and get particulars. contact your local AFP sales representative for details, or call 866-239-8475
Posted on Aug 06, 2009
Anonymous
  • 16 Answers
SOURCE: I had just finished cheese and couldn't get the
If still interested in a replacement for the Ultimate Chopper - there is a website call TV Time Direct - website: http://www.tvtimedirect.com.
Their phone # is 800.238.7119. On their website, use the Quick Find option (upper right corner) - type in Ultimate Chopper and it will list the replacement listing for this item.
Posted on Oct 13, 2009
Anonymous
SOURCE: Disc stem stuck...can't pull it off.
Hey I had the same problem. This may sound primitive and stupid but it worked. Give the stem a good whack with a wooden spoon all the way around, it will come off.
Posted on Dec 08, 2009
Left phil honey nut cream cheese out for 5 hours. it is still cool to touch, firm in texture, and no bad smell. is it ok to eat
Before refrigerators most cheese was kept at room temperature in a covered cheese dish. Soft cheese was kept in a pantry or a meat safe and only loosely covered.
Cheese is a fermented food and as such keeps much longer without spoiling than fresh food and yours contains honey which is a preservative.
Most cheese is also salted, which is another preservative.
Even when cheese has begun to turn bad I haven't ever heard of anyone getting ill from eating it.
Mar 10, 2018 | Ice Cream Makers
Tip
Making the perfect grilled cheese sandwich on an electric griddle
Most people when they make grilled cheese sandwiches try to stamp out as many as they possibly can as quickly as they possibly can. When you make grilled cheese this way you end up sacrificing a great tasting sandwich for just an okay sandwich. With just a little bit of patients and self control you can make a great grilled cheese sandwich that will keep your kids coming back for more.
It all starts with having the right equipment and ingredients to make the perfect sandwich. You can use a saute pan on a medium low heat but I prefer and recommend that you use an electric griddle set to about 275 degrees. To make the sandwich you need bread (we use sliced white bread), butter (at room temperature so you can spread it) and either cheddar cheese or sliced American cheese.
Before you start to make your sandwiches you have to set up the griddle and set the heat. The key is to have it ready so the sandwich starts to cook right when it hits the griddle.
To build your sandwich take two slices of white bread and the butter, lather up one side of each of the slices of bread with a generous amount of butter. You want to let the butter sit a bit so that it comes down to room temperature, this will make it easier to spread on the bread.
Lay the slice of bread with the butter side down and cover the whole slice with a single layer of cheese. Close it up and you're ready to start grilling.
Carefully place your sandwich on the grilling surface and let it sit for 5 minutes on each side. Don't put it down and walk away because you need to make sure that it doesn't burn. After five minutes flip the sandwich over and let the second side cook for another five minutes. You will know that it is done when both sides of the sandwich is golden brown. It may take longer than 5 minutes on each side so don't panic if after 10 minutes its not done.
When its finished you can put them on a plate and serve them up hot. In my house we like to open them up and put a tomato slice with salt in it. You can have it plain or with tomato soup, cut in half or whole, how ever you enjoy it.
Bon appetit!
on Feb 11, 2014 | Kitchen Appliances - Others
Tip
Perfect party dips, all made easy in a slow cooker
The best part about a slow cooker is that all you have to do is drop the ingredients in and let them simmer for hours.
Here are some of my favorite dips to make for a get together in my slow cooker.
Spinach and Artichoke - Cook on high for two hours
24 oz. frozen Spinach
2 8 oz. package Cream Cheese
1 cup shredded Parmesan
2 cups Mozzarella
2 14 oz. cans Artichoke Hearts Chopped
1 small Onion diced small
1 Tsp. Garlic Powder
1 Tbs. Horseradish
1 Tsp. Chili Powder
Bacon Cheese Dip - Cook for three hours on high
1 Package Bacon, cooked and chopped
1 16oz Package Cream Cheese
4 Cups Shredded Cheddar Cheese
2 Teaspoons Worcestershire Sauce
1 Teaspoon Hot Sauce
1 Cup Half n Half
1 Teaspoon Minced Onion
1/2 Teaspoon Dry Mustard
Salt to taste
Caramel Apple Pie Dip - Cook for five hours on low
5 cored, skinned and chopped Granny Smith Apples
1 Teaspoon Cinnamon
1 Teaspoon Allspice
1 (14 Oz.) Container Fat-Free Caramel Dip
Buffalo Chicken Dip - Cook for three hours on high, add cheese at the end
1 lb cooked chicken, shredded (can be store bought rotisserie)
8 oz. cream cheese, cubed
1 cup ranch dressing
3/4 cup Frank's Red Hot Wing sauce (The wing sauce is thicker and hotter than the regular)
2 cups shredded cheddar cheese
on Oct 14, 2013 | Cooking
I want to bulk buy a block of cheese mild cheddar from Cosco wholesaaler and would like to know how long it would last in the fridge wrapped up or can freeze it thanks x
it will last indefinitely wrapped properly (saran wrap) in fridge, you might have to cut a little mold off, that's no problem. your problem would be putting cheese in freezer.
Dec 04, 2016 | Refrigerators
What does not go well with cheese
A broad question. Please send more info if you'd like - glad to help. I am posting regardless:
(from website:)
http://www.thekitchn.com/what-not-to-pair-cheese-pairin-148014)
What Not To Pair: Cheese Pairings to Avoid
(We) talk a lot about what makes a great pairing when it comes to cheese, wine, and food. And since cheese is so rarely-- really, too rarely, in our opinion-- enjoyed just entirely on its own, it's especially important to know what foods will heighten your experience of the cheeses you serve.
Equally vital is knowing what not to do. (Oranges and carrots, for example, are just a preview of two things that just won't make your cheese sing.) Here, some don'ts to keep in mind when putting together a cheese plate.
When pairing foods with cheese, your goal should be to highlight both elements equally. Ideally, go for flavors that will accentuate rather than overpower the cheese itself. Similarly, cheeses shouldn't overwhelm what you choose as accompaniments.
The exceptions to the rules below may be fresh cheeses, which act as excellent foils to stronger flavors. But generally speaking, the following things are examples of what to stay away from when constructing a cheese plate with a variety of different styles, ages, and flavors:
Spicy things: There may not be a worse way to kill the flavors of your cheese. While a searingly spicy hot pepper jelly is actually great with a cooling, sprightly puck of goat cheese (see above disclaimer regarding the fresh cheese exception), it wouldn't do anything for the subtle flavors of a semi-soft, natural rinded sheep milk cheese, for example. Veer from olive mixes speckled with dried red pepper flakes, really spicy pickled items, spicy meats, hot jellies, mustards, or chutneys, and even crackers with black peppercorns. While delicious, these accompaniments will linger on your palate and hinder your experience of the cheese in its natural state. Lightly spiced things can be great with cheese, liked sweet, spiced nuts and herbaceous olives. But beware of things that taste more of what was used for flavoring than of the food itself!
Garlic- or Onion-flavored Crackers and Bread: Unless you want to be left tasting the bits of dehydrated onion or garlic that so often sully the surface of breads and crackers, save these items for other moments. And beware of the "Everything" flavor, too, which may have lots of onion and garlic lurking within. Some cheeses, like stronger mountain cheeses and some funky natural rinded wheels, actually have subtle notes of spring garlic or onion. Breads and crackers infused with onion-y flavors can mar these compelling undertones, so beware.
Vegetables: Clearly this is a category that may be a bit too large to generalize, so to be more specific, stick with vegetables that have relatively mild flavors, like sliced fennel and endive spears. Slightly peppery greens like arugula or radicchio can be great compliments to cheese if you're thinking of making a cheese-laced salad. But on a cheese platter, stay away from the most vegetal of vegetables, like broccoli, carrots, green beans, celery, and cauliflower. While these all may make great additions to a crudite platter (and broccoli and cheddar soup is undeniably delicious), they seem straight-up strange to pair raw with nice cheeses.
Citrus or high-acid fruits: Orange segments, grapefruit, kiwi, and pineapple have their place, but not on a cheese plate. While so many different kinds of fruits go seamlessly with cheese-- like apples, pears, grapes, and figs, not to mention all of the dried fruit that compliments cheese so well-- those fruits that are higher in acid tend to turn cheese acrid. My mouth nearly cringes with the thought of the curdling effect these fruits would have on cheese!
Tannic Red Wines are similar to citrus in their ability to turn cheeses bitter. The lingering effect of tannin on cheese can be so negative, you may walk away with an inaccurate opinion of what you're tasting. You'll ruin not only your impression of the cheese, but of the wine, too!
On a final note:
What do you call cheese that 'isn't yours'?
Give up?
"NACHO cheese"
Jul 11, 2014 | Games
What types of wine are best suited for pairing with cheeses?
Every wine can be used by very old cheese or dark choclat its simply a good combination especially truffle pecorino cheese with a good red Bulgarian melnik mavrud or a red Macedonian TIKVES wine ta ga zug is recommend.
Feb 03, 2013 | Wine & Spirits
Too much salt in crab dip
If you are talking about food, cheese contains loads of salt, just add natural yoghurt instead.
Jan 09, 2012 | Dryers
Coks essentials coontact grill cheesburger
These burgers are broiled, or use your grill and serve on toasted hamburger buns.Ingredients:
  • 2 pounds ground beef, lean
  • 1 tablespoon steak sauce, your favorite
  • 1 teaspoon Worcestershire sauce
  • 1/4 teaspoon hot pepper sauce
  • 2 teaspoons salt
  • 1/2 teaspoon pepper
  • 1 1/2 cups shredded American or mild Cheddar cheese
  • 1/2 cup finely chopped onion
Preparation:Combine ground beef, steak sauce, Worcestershire sauce, hot sauce, salt, and pepper. Shape mixture into 8 hamburger patties. Broil patties 4 inches from heat for 6 minutes. Turn and broil for 4 to 6 minutes longer, to desired doneness. Combine cheese and onion; place on patties then broil until cheese is melted. Serve on toasted hamburger buns.
Nov 02, 2011 | Cook's Essentials Cooks Essentials Arome...
Cooking Logo
323 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Cooking Expert? Answer questions, earn points and help others
