Question about FUJIFILM Cameras
Do I have to use a specific kind of memory card in my Fujifilm FinePix s700 camera? I've done tried two different ones that I have and obviously they are not compatible. Please help. Thanks
Posted by Brittany Buie on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
Anonymous
  • 3 Answers
SOURCE: Broken LCD Screen FujiFilm FinePix S700
i have a fuji s7000 that has a good lcd screen but the processor inside doesnt work. You could use it for parts.
Posted on Oct 30, 2008
Anonymous
  • 16 Answers
SOURCE: Fujifilm FinePix Z20fd protected card??
The memory card should have a little switch on it, try it in the other position. It is a safety lock to stop it getting wiped.
Posted on Feb 13, 2009
Anonymous
SOURCE: Can't copy pic from camera to memory card :(
I needed to be actually looking at my photos then go into the menu then its pretty straight forward.. asks if you want to save from the camera to the memory or vice versa..
Posted on Mar 27, 2009
Anonymous
SOURCE: finepix s700 says memory full and wont take more pictures with sd
i know this is late, but my camera had the same problem.
1. If you go in the setup menu.
2. Push the right button once and scroll down to the menu that says format.
3. It will ask you if you want to erase all data.
4. Select No and everything should be fine.
Posted on Dec 22, 2009
Fuji finepix s700 camera error message protected card. After making sure sd card in unlocked. I still get this message. I had trouble getting out a sd card,i feel a piece of the sd card broke in the...
Take a small flash light and see if there is a part of a memory card in there, if there is cleaning it out would solve the problem. Also make sure you're putting the memory card in the right way. I've you've done that and it's still giving you problems try going into the menu's and formatting the memory card in the camera.
May 10, 2011 | Fuji FinePix S700 Digital Camera
Tip
How to Recover Pictures From Fujifilm FinePix S700 Storage Media
With 7 mega pixel camera, 10x optical zoom, 2.5 LCD, picture stabilization mode, and i-Flash intelligent Flash, the Fujifilm FinePix S700 fulfills all the requirements of any photographer. The storage media (SD and xD memory cards) used in this camera allows the photographer to save audios, videos, and photos of different sizes. Damage in storage media can occur any time, resulting in fatal consequences, like inaccessibility of data saved in the memory card. In most cases, the photographer encounters an error message stating that the card is corrupted. To overcome such corruption scenarios, the photographer needs to restore the data from an updated backup. But all photographers do not create a backup on regular basis. For them, a third-party Camera recovery software acts as a boon and helps them recover the data.
As a real-world instance, you encounter the below error message while trying to view the pictures saved in your SD card (inserted in Fujifilm FinePix S700):
"CARD ERROR"
After the above error message pops up, the data saved in the SD card becomes inaccessible.
Cause:
Few main causes for the above error message are:
1.Incorrect SD card format.
2.Incompatible SD card.
3.Memory card corruption due to unexpected camera shutdown, virus infection, and interrupted read or write operation.
Resolution:
To resolve the above error message and to access the data saved in SD card, you will need to:
1.Use a compatible SD card.
2.In case of memory card corruption, format the card in Fujifilm FinePix S700 camera. Though formatting brings the card in reusable state, all the audio, video, and picture files get deleted. To recover the deleted data, you will need to choose a powerful Camera recovery software.
Such recovery tools use effective scanning methods to ensure complete Camera data recovery. These tools can be downloaded from the Internet and used by anybody. Such applications are safe as they harm the original data saved in the memory card.
Digital camera recovery software is a world-renowned Photo Recovery utility used for recovering data from almost every type of memory card. This software ensures complete recovery of digital files, irrespective of their size or type. Compatible with Windows and Mac OS X, the read only software also recovers data from other storage media, like Zip drives, hard drives, etc.
on Jun 30, 2010 | Cameras
Fujifilm finepix s5100 card not initialized
Have you tried to format the card in the camera not the computer it has to have the camera files on the card the camera will put the files it needs on the card.
Oct 03, 2009 | Fuji FinePix S700 Digital Camera
Accessing internal pictures from FujiFilm FinePix S700 digital ca
Take the xd card out of the camera and then you can access the internal memory.
Dec 18, 2008 | Fuji FinePix S7000 Digital Camera
"Card Not Initialized with 4GB CF memory card"
Steve, S700 and S7000 are different beasts.
S7000 is only rated for 1Gb compact flash cards. It apparently works with 2Gb ones but as I and a lot of others have discovered no matter how you tweak around sectors and clusters it won't read the thing.
This is a Fat16 limitation.
Sep 28, 2008 | Fuji FinePix S7000 Digital Camera
Memory Card Cover
Hey janest,
You can find a link below to the manufacturers parts department.
http://www.fujifilmusa.com/support/ServiceSupportPartsContent.do?prodcat=616757
Sincerely,
Allan
Go Ahead. Use Us.
May 15, 2008 | Fuji FinePix S7000 Digital Camera
Cameras Logo
51 people viewed this question
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
