Question about Haier Refrigerators
HAIER #HDE10WNAWW refrigerator : Freezer cold , bottom part Not ?
Posted by Crista Hjort on
richard libby
    Sergeant:
  • 209 Answers
Unplug and leave for 4 hours . then plug back in . turn temp up and reach in the back of fridge and see if you feel cold coming in from the vent. If not replace fan motor in freezer side .
Posted on Mar 04, 2019
5 Related Answers
Anonymous
SOURCE: haier bottom freezer
I have a haier compact refrigerator ESR042PBB.I lost power and when power was restored the refrigerator didnt work.Th einterior light came back on but the refrigerator wont cool. I checked the back and the cooler is hot.I unplugged it and let it stay unplugged over night. The next day I plugged it back in and left it for 24hrs.It still doesnt work.
Posted on Sep 18, 2008
Charles Caldwell
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
Mark Egan
  • 1214 Answers
SOURCE: anama bottom freezer
Chances are if they are getting cool -
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator/freezer.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 16, 2009
Anonymous
SOURCE: Refrigerator does not get cold
The refirgerator is not as cold as usual. But My freezer is really cold and working jus find... what do I do?
Posted on Jan 31, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Posted on Jul 03, 2009
There is a drip coming into the refrigerator from the ceiling , but the freezer is not frosted
I suggest that you remove the bottom layer of the freezer - you'll see its just a piece of plastic to allow cold air to circulate underneath. There is a metal tray in the back of the freezer there that has a drain in it - I'll bet its frozen solid and the condensation from the defrost cycles are dripping down into the fridge part.
Nov 16, 2011 | Haier HTE18WAA Top Freezer Refrigerator
The bottom part of the refrigerator does not cool at all
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Haier HTP18GAA Top Freezer Refrigerator
Freezer works fine but the the fridge is at 19C. Please help
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 27, 2011 | Haier HBQ18JACBB Bottom Freezer...
To top freezer is cool but the bottom is not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 01, 2010 | Haier BC328 Top Freezer Refrigerator
Haier HTQ21JAAWW ISSUES!!!
my refridgerator seems to be workin the freezer is getting cold but not freezing its a top freezer bottom refridgerator the fan in the freezer is also not workin.i had atec come out to check it out. supposedly theres a capasitor that sits next to the compressor that he told me was bad an had to be ordered.its got 2 wires that come off the compressor that plug into this lil box.my question is could this be why my freezer is not freezing an also why the fan inside the freezer is not workin?
Apr 02, 2008 | Haier HTQ21JAAWW Top Freezer Refrigerator
Repair
Defrost system problem will be indicated by frost (snow) on back wall or cooling coil is located in the freezer compartment. Check freezer control setting. If it is set to cold for the freezer it reduces cold air to the refrigerator section.
Mar 26, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Haier bottom freezer
Nov 07, 2007 | Haier Refrigerators
Fridge won't quit running and get cold
2 common problems that unit has. 1 is the cold controls go bad and will cause the unit to either run or not run. 2 the freezer drain gets blocked up very easy and when the freezer defrost the water has noplace to go but the freezer bottom and could block the air passages so the cold air will not satisfy the control. so check the freezer bottom by removing the plastic peice on the bottom there are 3 plastic plugs in the front that secure it and some phillips screw in the middle. you can just lift it to check for ice. if there is none replace the cold control. good luck
Aug 04, 2007 | Haier HTQ21JAAWW Top Freezer Refrigerator
Refrigerators Logo
96 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
