Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not getting water to the ice maker and the drinking water line is not working either. What am I doing wrong. There is water to the connection, but it not getting to the ice maker or drinking water.
Posted by valentinewin on
Anonymous
  • 36 Answers
Ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Posted on Aug 08, 2009
How do I hook up the plumbing. Do you have an exploded diagram of the back panel where all the water hook ups are at.
It depends on the refridgerator. Some have two inlet valves. Basically, you have a water line from the home. Usually copper line. You also will have two places for water lines on the opposite side of the inlet valve. Sometimes you may only have one. The line leading from fridge ( if ice and water through door) will hookup to the line where you have the fridge connactor. The quick connects to the inlet valve. The second one will be for ice maker. That water line runs up the back of fridge into freezer. Make sure you place the quick connects in the right spot. Process of elimination because some inlet valves wont let you change the hoses once installed. Connect the main water line from the home. Connect both quick connects dont connect water lines yet. Push the water thru the door botton and see which valve opens on the inlet. Which valve on inlet opened and allowed water to come out. That is for fridge and other is for icemaker.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Refrigerators
Water line for ice maker/cold water leaking underneath
Check your connection at the bottom of the freezer door, behind the kick plate. Also pull out your crisper drawers and check the cold water reservior. If this only leaks when the water dispenser is pressed I would try to track the line from the bottom of the freezer door back to where it goes into the refrigerator (behind the crispers) to the cold water reservior.
If you absolutely have to lay this fridge down lay it on it's BACK only. Also be sure to let it stand upright for at least a half an hour before you start it back up.
Good luck with this!!
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
My frigidarie refrigerator ice maker does't work
Jun 06, 2010 | Frigidaire PHSC39EESS Stainless Steel Side...
How do you get the ice maker to make ice consistently
Jun 06, 2010 | LG LSC27931S Side by Side Refrigerator
No water going to ice maker
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
How do I turn on the ice maker?
This might sound like a silly question but... is the water line connected on the back of the appliance? If so you may have something stuck in the water line, or a bad valve that is not allowing water to flow. Hope this helps.
Sep 09, 2009 | Refrigerators
Cannot install water line
I too had to scratch my head to locate where to connect the water line for the ice maker. Looking at the rear of the frig on the bottom right you will see a white plastic cover that the black plastic line goes into. There is a screw on the right side. Undo the screw and then pry off the white plastic cover. You will see a black plastic cap over the threaded water line connector. This is where you connect you line as approprite. I hooked up the line and turned the water supply back on and then you have to turn on the ice maker. I works great. Problem is the manual is not clear at all. Guess they assumed that the installler would be hooking it up. Once you know what to do is is a piece of cake. Good Luck. Doug S. in Poland, OH
Aug 11, 2008 | Refrigerators
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
875 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
