Just replaced Whirlpool Quiet Partner III, model #GU1200XTKQ0, ser # FM1441475 after functions began to fail. Lastly only Normal worked. After replacement, unit ran under ChinaCrystal mode- don't know why since I never selected this mode.. Now, Sani Rinse button flashes. 1. Tried Cancel- no effect 2. Tried Reset- flipped breaker with door open. Reset breaker, closed door, Sani Rinse still flashes.
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Testimonial: "Worked perfectly! Thank you."
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
SOURCE: Quiet Partner II Whirlpool Dishwasher 2 years old,
Unusual LED or Display Readouts Open ID diodes and/or LED circuit(s) in keypad, or open circuits on the control that drive
See "Checking Keypad Operation."
Press the following in sequence...Then try touch pad......
HEATED DRY ? NORMAL ? HEATED DRY ? NORMAL ? HEATED DRY ? ORMAL
here is the deal...if the touch pad is unresponsive after entering the above in sequence then you will need to change out the touch pad.
here is the link to your model....part number 1 on the drawing...there are three different ones....the difference is the color.Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-DU1100XTPBA/1198/0130000/W0702219/00002?blt=06&prst=&shdMod=
Here is a link that will show you the three differnet colors...I would order from these guys....1 year warranty on parts no questions asked
click on the link http://www.repairclinic.com/Touchpad-Parts?s=t-DU1100XTP-%3d%3dc63
SOURCE: We have a whirlpool quiet partner iii. It was
see this causes and fix it. God bles you
Check Fault Codes
If the display lights are flashing and there
is an error code in the display window, check the Error Codes guide on
our website to determine which component has failed or is failing
Touchpad
If the display lights are flickering for no
reason, the touchpad might need to be replaced. Sometimes when the
touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel
If the lights are flashing on the display the
entire touchpad and control panel assembly might be defective. If the
display works but the dishwasher functions are all out of synch, or some
of the buttons don't respond properly the entire touchpad and control
panel might need to be replaced.
Heating Element Assembly
If lights are flashing on the control panel,
the heating element assembly might have burned out. The heating element
assembly heats the water up to operating temperature. After a set amount
of time if the temperature isn't reached a light on the control panel
might start flashing. The heating element assembly can be checked for
continuity with an Ohm meter.
Heating Element
the heating element might have burned out. The heating element heats the
water up to operating temperature. After a set amount of time if the
temperature isn't reached a light on the control panel might start
flashing. The heating element can be checked for continuity with an Ohm
meter.
Drain Pump
the drain pump might not be working properly. For two-wire drain pump
motors check them for continuity using an Ohm meter. If it's defective
YOU'LL need to replace it. Drain pumps are not repairable.
