SOURCE: 06 polo headlamp (whole unit) bracket broken..???
whole unit,remove front bumper to get to bottom bolts
SOURCE: front seat bracket underneath
i had a similar problem, i just put a washer over it with epoxy, and cranked it down. problem solved.
SOURCE: Jaguar Front License plate bracket
I had the bracket upside down was the problem and now is attached properly
NISSAN STANZA WAGON - Manual Transmission
Q. Where is the starter on a 1986 nissan stanza station wagon and how do you get to it ?
Due to limited access to the starter, it is recommended that the transaxle be removed when servicing the starter.
REMOVAL:
1. Cold vehicle.
Remove 2 mounting bracket bolts, 10 & 12 mm (Figure 1).
Remove top starter motor bolt 14 mm with universal & long extensions.
Raise vehicle on hoist.
Remove front splash pans 10 mm.
Automatic transmission: Drain 2 qts out.
Remove rt-ft wheel 21 mm., & tie rod (Figure 3), axle cap, cotter pin, adj-nut & rubber washer.
Remove ball joint nuts 17 mm., left lower control arm 19mm. & swaybar bracket 14 mm. (Fig 2).
Remove axle nut 36mm (Figure 4), the front tube, catalytic converter heat insulators 10mm, ctr ex-tube 17 mm., and front tube from exhaust system (Figure 5).
Remove long bolt from ft engine mount (next to radiator), 17mm socket (Figure 6, Item A).
Remove tension rod mount 14 mm. Has adj-bracket with rubber insulators (Fig 6, Items B, C).
Remove right side drive shaft bolts that hold shaft to bracket mounted on engine (Fig7) 12mm.
Remove rt-driveshaft.
CAUTION: Transaxle side seals are cut by spline teeth.
Install hoist type transmission jack and wooden block under the transmission/engine. Be certain the transmission is safely balanced on the hoist.
Remove 5 engine crossmember mounts (3 bolts, 2 nuts) 14mm.
Remove nut that attaches crossmember to engine mount.
Loosen stabilizer bar mounts to allow adequate clearance for crossmember to be removed.
Remove following brackets to allow starter assembly to pass through bottom:
tubular support bracket - engine to transaxle
angled support bracket - driveshaft bracket to engine mount
manifold collector stay - (bottom bolts)
Loosen top bolts, remove bracket above driveshaft-holding bracket 14mm.
NOTE: This bracket is slotted to allow it to slide out without completely removing the bolts.
Remove bottom starter motor mounting bolt.
Separate starter assembly from bellhousing, DC all cables/connectors, remove starter motor.
When installing starter, connect cable, install/torque starter bolts.
REMOVAL & INSTALLATION
See Figure 1
