Dishwasher shuts off after about 15 minutes. start/reset led blinks, water drains, dishes are not cleaned
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry .
Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button
and allow it to completely drain and reset. If this doesn't work then it's an
issue with the wash pump not pumping the water past the heater efficiently or
due to lack of water to heat. Please make sure that heater is not open
circuited and is heating the water efficiently. You'll have to check the heater
using a multimeter; the meter should read between 3000 to 3300 ohms (Use
multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure
is optimum and fill valve is working fine. Hope this helps... Please post
back if you need more information.
Daniel
Hi
Thanks for using FixYa. F1
error means that the flood switch has been activated. You'll need to reset it by powering off the
breaker or by unplugging the unit from the power socket and mains for more than
five minutes. Please check that there is no blockage in the drain hose and it
is not raised higher otherwise the water will run back to the dishwasher. Also
perform the following procedure---
Please rate the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
