My TV model number is LG OLED55C8PUA
This is a fairly new model and if not under guarentee try changing the batteries on remote. This TV comes with a remote that has a very poor record.
Testimonial: "When i disconnect one of the lvds cable from the T-con board the TV Turns on but gives no display but has sound working"
First I want to warn you about testing any part of the TV power supply. Please take the necessary precautions to ensure the safety of you and anyone else.
If you open the TV follow the power cord and where the power cord plugs into the TV, there should be a power board. On the power board you will see a number of capacitors. They are about 1" high and about 1/2" dia. This is where the electricty is stored for power to assist starting the TV. Be very careful when you handle that power board. Look at the top of all the capacitors and if any one of them is domed, bulging or looks like they are about to come apart. Then those capacitors are defective. Each capacitor must be absolutely flat on top. As I said before, not flat on top...replace the capacitor. You don't need any special training. But it would be better if you had some experience in soldering. I'm not an expert in TV repair so I'm only offering my solution that worked for me. Let me know the outcome, please.
Thanks
Robert Mercer
If u take off the back you may get lucky and have a blown fuse. It wont be far from the place the wires from the plug in connect to the board. There is a power transformer in there that drops the voltage from 110 to 12 and is often protected by a fuse.
It has malfunctioned and has no user serviceable parts.good luck
sounds like you main board is damaged.
https://www.6ya.com/mrmmike
Testimonial: "I can avail parts for this model if you help me to find the problem with the tv"
Sure you can go herehttps://www.6ya.com/mrmmike and I can start the process of instructing you on how to find the problem and repair it. Video call would be better. You can also post another question and I can ignore it so someone else could offer you a solution- keeping in mind that I am one of the most advanced here. Anyone on my level will not be diagnosing your tv here one fixya- We are repair experts but fixya is not a repair/ diagnostic site... we help you here not offer repairs
good luckhttps://www.6ya.com/mrmmike
replace the main control board btw
is my short answer
ok it sound like the main board is shutting down due to power fault- have you verified the voltages on the power supply? also look for bad caps and other damaged parts while your st it
but when I disconnect the cable TV turns on everything works fine except for display,the TV detects the USB when I connect it to the TV. So how can the main board shutdown? Voltages on the power supply are normal and I can't see any bad capacitors.
The lvds has fault lines as well as the inverter, the motherboard can sense faults and improper voltages and shut itself down, you need to stop sir before you hurt yourself. Your too lost, I say that with respect
Good luck
SOURCE: Lg 42pc1da plasma tv wont turn on
will be a fault with either power or y-sus x-sus board is the tv still under warrenty if so request repair
SOURCE: LG RE-44SZ21RD 44
This is vcaused by a relay similar to a fluro/ neon light starter switch. This part has failed so it cannot get syncronization You will neede to have a serviceman replace this part.
Please rate our help to keep the free service online
SOURCE: LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Testimonial: "cheers man thats what it was."
SOURCE: I have an LG plasma TV, model: 50PC1DRA. We had a
Defective power board. Maybe best to call local service man.
