Question about Frigidaire Microwave Ovens
It seems that the touchpad on Frigidaire Microwave, Model FPBM3077RFB doesn't work. When i push on the wiring above the door hinge at the connector, it works on and off. Can i fix the connector?
Posted by Kelley Watson on
Mr.Mike
  • 580 Answers
If you have knowledge of how to do this type of thing you sure can, providing the connection is the problem- it very well might not be.
good luck
https://www.6ya.com/mrmmike
Posted on Mar 02, 2019
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: Broken hinge
TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. The lower hinge attaches the same as the top. If you found any of these suggestions helpful, please rate my solution. D. Lange
Posted on Apr 26, 2009
Anonymous
SOURCE: Frigidaire FMV155DC - defective door interlock switch
I had the problem where the timer continues to count down but turntable doesn't turn, fan doesn't come on and food doesn't heat. Holding the door up worked for awhile but even that temporary method stopped working.
I bought a door interlock switch the cost $23 from an appliance repair place and replaced it myself. It worked like a charm. To replace the switch, you need to remove 3 screws that hold the plastic grille above the door, which exposes the 1 screw that is holding the control panel. Remove that screw and slide the control panel up to remove it. There are three switches left of the panel. Note the middle swich has a different part number so I'm not sure what that one is called. The bad one on mine happen to be the bottom one. The switch is held on by a "pin" and tab that holds it in place. Push the tab and spin the switch on its "pin" past the tab to remove. Reverse your step to put the new one on. I hope this helps.
Posted on May 09, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Model mh1150xms3 displays F2 and touchpad stops working
F2 on a Whirlpool microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it cooking unattended.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part numbers to order are shown below by color you can get it here.
8185286 White
8185288 Biscuit
8185287 Black
8204739 Stainless
You can also find helpful exploded view diagrams at that link.
Posted on Aug 04, 2009
joeguest2
Joe2
  • 2080 Answers
SOURCE: Need a user manual for
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137230en.pdf
And here is a link to the wiring diagram for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/5995451720.pdf
And here is a link to the installation instructions:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316137233en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 25, 2011
SOURCE: frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Posted on Apr 16, 2012
My Frigidaire microwave door is sagging and about to fall off
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
Apr 24, 2015 | Frigidaire Model PLMVZ169GC Microwave Oven
Microwave does not come on.....but when i hold up oven door a little it comes on.
Frigidaire microwave FMV156DSB. Turntable don't turn and no heat. Clock, keypad, light and fan works. The guys above looks like they right about either the door or the switches for the latch. This model does have two switches and a fusible switch. Pushing up a bit on the oven door from the bottom right corner when its closed make mine turn on if you set it to cook. Switches numbered 8(x2) on the schematic has part number 5304440026 $18.05. Fusible switch has part number 5303319559 $30.36. Have'nt changed them because it may be the door hinge is bent since the door latch is made out of plastic. Also looks like a real pain to take apart just to get to the switches. I will try to bend the door hinge to see if it fixes it. "And..now." -- Kirk, "Huh?" -- Scotty, "The doors, Mr. Scott." --Kirk, "Aye. I'm workin' on 'em."
Mar 11, 2011 | Frigidaire FMV156D Microwave Oven
FMV 156DSB Timer and light works, but does not heat unless you push up on bottom of door.
Slacken off the lower hinge screws and re set the door to the correct height, then tighten them back up.
That should sort that out.
Jan 02, 2011 | Frigidaire FMV156D Microwave Oven
How to replace door for frigidaire fmv156dc
If you remove the vent above the door, a couple of phillip screws hold it on top, it slide off to the left, open the door and pull up on door, look at hinge and remove off of tabs
Sep 03, 2010 | Frigidaire FMV156DC Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
We need to change the door on our microwave. We have the new door, but can't find anything in the manual about removing the old door. It is a Frigidaire Gallery series above range microwave. Any...
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Sep 05, 2009 | Kenmore 62622 Microwave Oven
Frigidaire microwave door fallen off
I had the same problem. I removed the door and used a rivet tool. I checked to make sure the door cleared the rivet head, which was nearly flat, so there would not be any microwave leakage.
Jun 28, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave oven stopped working
OMG!!! This was perfect. I had the same problem. Timer was on but the fan nor the table turned. Just when I was about to take the thing and chuck it in the trash, I thought I'd give the above method a try. I turned the microwave on, and nudged the door sligthly upwards.... miracle! it started to work. to make it permanent, I took the door off (the cap on the inside of the door, on the upper hinge needed to be removed with a flat head screwdriver, very easy, just pry it off). Once I took the door off, I placed a small washer on the bottom hinge to raise the door slightly. Put the door and hinge cap back on... and Voila! The microwave works now. Thanks for the help guys...
Jan 20, 2008 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
162 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
