Assuming your table is level and even, is the bowl itself even also. Check it for even thickness throughout the whole edge that sits on the table top. If that is even also, then you may have to cut part of the table that the bowl sits in so that it will allow the entire sink to sit flat.
could be moisture can affect a laptop in stages keyboard then motherboard might want open it and tent it(edges on table) and then lightly run a warm hair dryer over ports, keyboard etc you might get lucky
If you know how to do this open the latch on the cassette when it stops and look to see if something got spilled into or on the tape itself.
If the unit only shuts off with this tape the cassette is the issue.
If you open the door on the tape (little square button to release the door also look (happens if you use same tape a lot and fast scan with it) to see if the bottom edge of the tape has curved waves in it--should be perfectly flat with no ripples at bottom edge of the tape.
Most often, the idle air valve is what people tend to be told to go and replace. Now true, this may improve this poor performance and shutting off for a while, but until you wipe the inside of this throttle body clean, including the edges of the butterfly door inside it, until it is free from the varnish that causes it to stick, this will continue to cause you aggrevation...
the most common problem with gas appliances not running is the flame probe. This device detects a flameout and shuts the gas valve. It could be faulty or not sitting in the flame itself
windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes wipers will shut off. When needed again same thing will happen This is on a 2003 Chevrolwt express Va
