Question about Samsung Computers & Internet
Can Windows 7 be installed on Samsung V25 - Samsung Computers & Internet
Posted by Ajibade Ayomide on
Samsung v25 power on password
you should have been given a 7 digit number when it boots to password need this to get access code
Jun 07, 2012 | Dell Inspiron B130 Notebook
I ave Samsung V25 laptop after a blue screen shutdown, my laptop now tells me i do not ave Genuine Windows. Ive tried activating genuine windows but no luck.
choose to activate via the phone call the free phone number and follow the instructions
if this helped please vote for me
Feb 26, 2011 | Samsung Computers & Internet
Printer installation problem for Samsung V25 laptop.
The issue is with the driver compatibility.
First I would ask if the recovery is latest?
Or else after the recovery update it with the web so as to get the latest service pack like sp3 for windows xp.
Second thing is that you can try to download the latest driver from the lexmark manufacturer.
Sometime with the latest driver update and will correct the the bugs.
Try this...
Feb 15, 2010 | Samsung V25 XVC 2800 Notebook
Samsaug v25
well, i have had the same promblem,hate to say it but sometimes the type you bought isn't compatable with your laptop ...mite consider saleing that one and asking samsung what kind of cdrw's will work with that laptop
Jan 05, 2009 | Samsung V25 XVC 2800 Notebook
Which hard drive fits in my v25 samsung notebook?
You can use an IDE laptop Hard Drive unit from 40 GB. to 100GB. That laptop came with a 40GB.
Hard Drive
Hard Drive Capacity 40 GB Storage Controller Type
Specs are at this link:
IDE
http://www.shopping.com/xPF-Samsung-V25-XVC-2800-NV25NQ0VLR-SUK
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 01, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25 shutdown
hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site: http://www.microsoft.com/whdc/hcl/default.mspx
Mar 22, 2008 | Samsung V25 XVC 2800 Notebook
Open Questions:
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
