Question about Whirlpool Washing Machines
Whirlpool awm 029, how do I check the weights for tightness.
Makes a lot of noise on spin cycle, I have replaced the shock absorbers, sounds like loose weights
Posted by Robert Clarke on
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Posted on Nov 25, 2008
Anonymous
  • 734 Answers
SOURCE: AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Dec 12, 2008
Anonymous
  • 239 Answers
SOURCE: Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Posted on Aug 30, 2009
Anonymous
  • 7 Answers
SOURCE: Washer makes knocking noise while in spin cycle.
Check your front and rear counter-weights. They are made of concrete and start to chip away. More so the rear than the front. When you open it up look on the base and see if you have chips or chunks of concrete. I had that problem as well - also make sure you spray lube inside,check your "Spider" wheel, and belt.
Posted on Aug 11, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: We have a 10 year old Kenmore front loading washer
It appears your drum roller/guide has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Loud squeeling grinding noise
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Oct 02, 2014 | Whirlpool Cabrio WTW8600YW 28" Top Load...
My washer has begun making a LOUD whining/whirring sound in the spin cycle.
Oct 01, 2014 | Whirlpool WTW6400SW Cabrio Washer
How do I fix the last few seconds of spin that vibrates off balanced and aloud noise.
By the way my advice is free cuz God is good!
Sep 23, 2014 | Samsung WF419AAW 4.3 cu. ft. Front Load...
My drum is loose and won't spin even by hand
Sep 21, 2014 | Whirlpool Washing Machines
Whirlpool probleme
Sep 01, 2014 | Whirlpool Washing Machines
My ultimate care 2 washer is full and makes. a loud noise when I turn it on. Nothing happens. It doesn't drain
Aug 06, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
How do I fix a loud noise during the spin cycle in my whirlpool duet washer ghw9400plo?
Aug 06, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My washing machine makes an excessive clicking aand thumping noise. is this normal
Jul 30, 2014 | Whirlpool Washing Machines
Hi.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
hi there,
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
48 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
