SOURCE: trying to hook up laptop with haier tv using vga
Dod you use HOTKEYS on the laptop to tell it to send the signal the VGA outlet of the laptop? The hotkeys function can be set to turn off the laptop screen and only have external monitor to be the only display or it can be set to have both of them on.
SOURCE: Monitor has no signal
have you tried you PC with another Monitor?
I'm expecting that you still have same problem.
Is your PC making any audible noise, beep sounds?
May be you should have your PC checked
Yes you are correct as it is only HD ready and likely will not work as you are trying to use it.
