Question about Sharp Cell Phones
Sharp copier mx-m464 white print out problem guys how can i solve this problem i change the developing unit and the problem was not solved how can i solve
Send me pls on [email protected]
Posted by tensae yewtha on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Sharp copier sf 2530 developer reqired error code (ie indicator on)
It's hard to be sure because our model numbers are different but drum reset should be 24-7 and dev reset should be 24-6. Good luck
Posted on May 30, 2008
Anonymous
SOURCE: MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Posted on Apr 02, 2009
tehnik_bdg
Budi Raharjo
  • 91 Answers
SOURCE: problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Posted on Jun 05, 2009
Amanuel Tsige
  • 30 Answers
SOURCE: why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
Posted on Jun 08, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
I have white horizontal lines through the text when printing A4 portrait. What can I do to solve this?
Look at your black development unit, if you see a white band on the development roller, remove the development unit, shake it and turn the gear of the development roller ...
Jun 01, 2011 | Ricoh Aficio 1224C Black and White Copier
It's asking me to change the developer unit! What is this?
The developer unit is the part that is supposed to distribute the toner to the particular drum or photoconductor. a broken developer causes a faint or white line or even band in the concerned color. This is usually a difficult part to replace and the job is mostly very dirty. i advise contacting a technician.
Sep 27, 2010 | Sharp MX-2300N Color Copier
Printer prints out black very light
First change you photo conductor unit if not solve
change the developer unit ( Ink ) If not solve
Clean the scanner glass of the printer.
Note that don't displace the glass just wash with a white dry cloth
Thanks
Oct 26, 2009 | Dell 5100cn Laser Printer
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
Cell Phones Logo
65 people viewed this question
Top Sharp Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
