Question about Samsung Office Equipment & Supplies
I have a clx6260 samsung printer and I get a MP tray empty and will not print, how do I fix this problem
Posted by Fanie van Rensburg... on
Norman J Weimar Jr
  • Samsung Master
  • 6,960 Answers
MP Multi Purpose Tray place paper in the tray or change your setting in the print driver
Posted on Apr 13, 2019
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: The paper tray has paper
MP - is the manual tray on the side. Sometime I've had trouble with switch that locates the paper on the side. Joggling the paper has helped me.
Posted on Oct 26, 2008
Anonymous
  • 44 Answers
SOURCE: "490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Posted on May 12, 2009
Betino Mih
  • 19 Answers
SOURCE: MP tray empty?
MP Tray = manual tray
Change properties from your driver (change the tray)
Posted on Aug 06, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Posted on Aug 18, 2009
Anonymous
  • 161 Answers
SOURCE: I have Samsung CLP/610 laser printer and need to
"MP tray" refers to the manual paper tray. This is the common setting for most word processors whenever printing media other than paper. This message will come not only for labels, but for transparencies, card stock, envelopes, etc. The reason for this is that the manual paper tray is designed to provide a straighter paper path that helps preventing your labels from peeling inside the unit. Therefore, I do not recommend placing them in the regular paper tray. Take note that you should also check that the labels purchased specify they are meant for laser printer or copier. Regular labels, or labels designed for inkjet printers will surely come off inside your printer and cause damage that the warranty will not cover.
Be blessed.
Posted on Apr 16, 2010
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
MY PRINTER SAYS ...MP TRAY PAPER IS EMPTY DURING PRINTING
Put more paper in the Manual Feed tray to allow it to continue or change the settings to bypass Manual Feed Options.
Sep 12, 2014 | Dell 2355dn AllInOne Laser Printer
My Samsung CLX-6220FX Printer says the paper is empty in the MP tray
Power the printer off, make sure all the trays are all closed properly, then power it back up again. Your printer is fine, the error will stop after restarting it in a full circle.
Aug 01, 2012 | Samsung CLP-500N Laser Printer
Be blessed.
Apr 15, 2010 | Samsung CLP-500N Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
MP Tray Paper Empty
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
Paper Empty in Custom Tray message
there's something wrong with the paper sensor
Jul 23, 2009 | Samsung CLP-510 Laser Printer
Oct 18, 2008 | OKI C5500n Printer
Fs-1030d even when set tray1 as source will print from mp feeder if paper in it
If paper in mp tray it can print mp tray only,
There is no option to chane the settings.
Oct 14, 2008 | Kyocera Office Equipment & Supplies
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
