Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
