Hi!
Here I'm adding a link to manual of a similar Maytag dishwasher. Hope it helps. https://manualsbrain.com/en/manuals/1261364
SOURCE: I have a kitchen aid dishwasher model #
you need to see if your getting power from the control all the way to the heating element something in the heating system is not working. some times the element burnes out and takes out the other stuff with it, so check for continuity at the element and thermostats befor replacing the control if all are bad it cost as mutch as a new washer or allmost
SOURCE: Maytag dishwasher model MDB9150AWB -on the 'rinse
I believe your model of dishwasher requires hot water inlet connection. Have you checked the inlet water temperature is within the recommended range per the user manual?
SOURCE: turn power on dryer maytag
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: F09 error on Maytag Bravos 10156733A Dryer
The only problem is going to be is the control board. I am not aware of the "error code F06" so this makes it even more likely that the control board is bad. I get all my parts thru AppliancePartsPros since they give a 365 day, any part, any reason return policy which is great. Here is the board to order.
Regards,
Richard Roth
http://appliancecafe.com
