Question about GE Dishwashers
Ge nautilus ,after cycle dishes have white residue on them?what can I do
Posted by brian on
ray gallant
    Top Expert:
  • GE Master
  • 67,926 Answers
ADD RINSE AIDE
Posted on Mar 01, 2019
5 Related Answers
Anonymous
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
Anonymous
  • 276 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
If your dishwasher is cleaning poorly, check these:
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
Mike
  • 677 Answers
SOURCE: white residue on dishes after wash
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Dec 18, 2008
Mike
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
Posted on Jan 06, 2009
hvac1
Cris Sparks
  • 338 Answers
SOURCE: My dishwasher is leaving a film all over the dishes
you might try to put one cup of vinegar in the washer and run the wash cycle with this in it no dishes in is while you are doing this. We live in the country and my wife had this happen and we used vinegar and it stopped this lime build up. Not an expert on this but it worth trying.
Posted on Jul 06, 2010
Testimonial: "This worked very good my dishes are sparkly and clean again. Thank you"
When I am unloading the dishwasher the dishes have a white residue on them as if the soap wasn't rinsed off enough and many times the glasses have little bits of food stuck in them
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 22, 2011 | GE Nautilus 24" Built-in Dishwasher
After 6 years, started leaving white film on dishes and silverware
Run a cycle with some CLR instead of soap, empty no dishes, run two more cycles with just water to rinse out the CLR and then see if the residue is gone, that's the cheapest, the other is some of the jet cleaners out there that clear out the jets that spray the water but I have no clue on the cost of those
Jan 20, 2011 | GE Nautilus 24" Built-in Dishwasher
The dishwasher does not get my dishes clean. it leaves heavy residue on all that is in the washer. it worked fine but now it is not getting the dishes, silverware and glasses clean at all.
heatman101
Nov 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Food residue left behind on my dishes on the top rack. The addition of a rinse agent doesn't seem to help. Suggestions?
heatman101
Oct 17, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher leaves a white residue on my dishes and just doesn't seem to be cleaning dishes right. it is also kind of loud.
heatman101
Oct 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Soap (?) residue on dishes; also not getting them clean--food on
heatman101
Jul 26, 2010 | GE Nautilus 24" Built-in Dishwasher
The center tower is not able to go all the way down after a cycle
heatman101
l;
Jul 17, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is making funny noise and leaves
heatman101
Jun 13, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher just started leaving food residue on dishes after washing. We usually don't rinse beforehand but even when we do this it's still happening. Can I run something thru a cycle to give the washer a...
heatman101
Mar 08, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
