Question about Binatone Lands Phones
I have a binatone spirit 410 corded phone. I have followed instructions to store numbers in the phone but not storing. Can you please help me
Posted by Allyson Timm on
  • putley7200 Nov 07, 2019
    Leave handset down dial in number press set to then whichever M number you require then pick up phone and press your M will dial the number you wanted this will also work if you want to override a number ok
5 Related Answers
Anonymous
SOURCE: programming binatone e920
Key the phone number - press memory - then press the green phone button
Posted on Jun 28, 2008
Anonymous
SOURCE: Programming GE corded speakerphone
I fixed this just now on my phone, while seeking a solution here.
- Do not do what you'd think... putting the phone and name info first. It looks like it will take this info but it won't. That's where the frustration comes from.
- Dial the PHONE# FIRST.
- THEN click STORE.
- Then click the location (A-C or 0-8... save 9 for 911 if you don't have a red emergency key).
- Then click STORE again.
- Then type in the phone number again... this works, though there's probably a way to do it w.o putting in the number twice... but since it works, don't sneer at the free advice :) LOL.
- Then click Store
- Then type in the NAME
- Then Store.
Done. Repeat for other names/numbers. Now that you have it down, you can figure out how to do this without entering the phone number twice... but since I have a busy day, I'm just doing it this way.
Best wishes!
Posted on Jul 29, 2008
Anonymous
SOURCE: Call Customer Service 1-8O5-465-751O To Fix Issue Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Posted on Oct 30, 2008
Anonymous
SOURCE: BINATONE concept 2300 combo
instructions to store phone numbers in binatone Concept 2300 combo
Posted on May 01, 2009
Anonymous
  • 39 Answers
SOURCE: lost the manual how do I store phone numbers
Press STORE button, LOCATION? shows in display, press the memory location (0 to 9 or quick buttons A to C) then press STORE button again. Dial the number you wish to store and then press STORE again. Use the number keys to enter the name of the person you have just stored and press STORE again. I hope this was useful.
Posted on May 13, 2010
When following the instructions for progamming one touch dialling, the result end with a message saying 'not valid' when trying to use the number - can anyone help?
Press Program Press the button to store Press 2 then your outside line access code (usually 9) Then dial in the number to dial Press Store
Oct 03, 2013 | Panasonic KX-T7730 Corded Phone
How do I store numbers on the phone system.
From the phone connected to Jack 01 (probably ext 101) press PROG **1234 001. Then press SP PHONE and you should be looking at speed call bin #001.
SP PHONE steps you through the numbers and all numbers you add need to include the trunk access code, be it "9" or "8x" before the number. STORE saves it.
Carl
Mar 25, 2009 | Panasonic KX-T7433B Corded Phone
Jan 27, 2009 | Lands Phones
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
STORING NUMBERS KX-T7750
Store a number in the phone memory
  • Press “Program” key
  • Press “*”
  • Press “ #”
  • Press “1234”
  • Press for number“001” for name “002”
  • Press “SP-Phone” key
  • Press “SP-Phone” key (de là if faut choisir le speed # on pressant sur cette clé)
  • Press “9”
  • Enter phone number (as dialed normally)
May 14, 2008 | Panasonic KX-T7730 Corded Phone
2 - Hit 'Store'
6 - Hang up!
Oct 06, 2007 | GE 2-9438C Corded Phone
Programming numbers into telephone
to store a speed dial on the kx-t7730 with the Advanced Hybrid System KX-TA624 you press the following keys
<pick up the receiver>
<the number you want to have as speed dial>
<the number you want to dial>
<press the square shaped key next to 0 and 9>
<wait for dial tone to return>
<hang up>
To call using the now saved speed dial, press the square shaped key and then the number you have saved to speed dial
For example
<pick up receiver> 2*1555555555<square key> <wait for dial tone> <hang up>
This will mean that when you press the square key and 1, it will dial 555555555
Oct 03, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
418 people viewed this question
Top Binatone Lands Phones Experts
Marvin
Marvin
NOEL
NOEL
Ngoro
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
