Washing Machines Logo
neeraa singh Posted on Feb 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to only spin clothes in delicate programme of LG turbo drum washing machine . Am unable to use it , pls guide.
keith jones
Level 3:
Master:
  • LG Master 747 Answers
  • Posted on Feb 28, 2019
keith jones
LG Master
Level 3:
Master:
Answers
747
Questions
Helped
314515
Points
1478
Most delicate cycles will not allow the machine to spin this is to prevent damage to the delicates
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Apr 23, 2008
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Anonymous
  • 30 Answers
  • Posted on Nov 11, 2010
SOURCE: I need instruction manual for
http://www.lg.com/au/common/product/support.jsp?localeCd=AU&productId=WT-R107&uri=/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-R107.jsp#
Hope this helps
Anonymous
  • Posted on Feb 20, 2011
SOURCE: I have a LG Turbo
Lg washing machine no drain error
Anonymous
  • 6277 Answers
  • Posted on Mar 29, 2011
SOURCE: LG Turbo drum washing machine
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
marley mcelhinney
  • 490 Answers
  • Posted on Oct 14, 2011
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
1helpful
HI, I HAVE A LG 8.2 FUZZY LOGIC TURBO DRUM THAT DOES NOT SPIN PROPERLY THE CLOTHES STILL HAVE WATER. IT IS LIKE THE SPINNING DRUM HAS SLOWED DOWN.
2 possibilities here:
Faulty water sensor. The water sensor's job is to sense the weight and how much water has to be spinned out. If you have a full load in the machine and the drum spins like the it had an arguement with the rest of the machine, then the water sensor is the culprit.
Or.
The belt pulling the spinner drum is stretched and could be slipping instead of gripping(pardon the rhym) :)
Replace belt
My WMC-568S washing machine
Feather or flower
Feathers are often used to depict washes for sensitive or delicate clothes. This is particularly important because these can be damaged when using a normal programme.
Arrows
Quick or super quick cycles are represented by multiple arrows going in the same direction, often beneath an outline of your washing machine drum. This option is especially useful when you're short of time, as you don't want to leave your clothes to crease because you're not around to take them out.
Butterfly
A butterfly will often signify silks, which are a form of delicate. Washing them on the right setting - this one - is therefore a must.
Full and part-spiral
While a full spiral means spin, one that is disjointed - or a part-spiral - indicates a gentle spin. This setting can help to reduce creases, which is something you may want to bear in mind when cleaning difficult-to-iron items.
E symbol
The E symbol stands for economy. This can be a great way to reduce running costs as it uses less water and electricity for smaller wash loads. Those of you wanting to reduce your outgoings may find this a very useful feature indeed.
Numbered clothes
Shirts with numbers on tend to depict sports clothes. We all know just how dirty our football kit or running gear can get, so this option is ideal for getting rid of all that sweat and mud.
How do I set spin only for Zanussi Lindo100 ZWF 71263W/71463W washing machine?
Spin
With this option you can change the default spin speed.
The indicator of the set speed comes on. Additional spin options:
No Spin
• Set this option to deactivate all spin phases.
Only the drain phase is available.
• The related indicator comes on.
• Set this option for very delicate fabrics.
• The rinses phase uses more water for some
washing programmes.
Rinse Hold
• Set this option to prevent the laundry creases.
• There is a water in the drum when the programme is completed.
• The drum turns regularly to prevent the laundry creases.
• The door stays locked. You must drain the
water to unlock the door.
untitled-pqbhbvgkecedzsp304arfp23-2-0.jpg Dado
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Lg turbo drum
Check if the counter balance weight is still attached. Sounds like a balance problem.
Bruno
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
12helpful
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
