Question about Sharp Audio Players & Recorders
My sharp stero 3 disc rotater wont opeon and shows me er-cd 11 what do I need to do?
Posted by Joshua Davis on
5 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
Posted on Sep 17, 2008
nuwan chinth
nuwan chinthaka
  • 111 Answers
SOURCE: The cd trays will not open, giving me a er-cd 11
youhave to check the all whole mecanisum to find ths prob.
nuwan.
Posted on Jan 14, 2009
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: My sharp cd player is showing error 11. door will
dismantle your cd player and set it up back and it will automatically reset itself. if does not then have a tech repair it as your aduio output is damage or the momory chip needs to be replaced.
Posted on Apr 18, 2009
Anonymous
  • 12 Answers
SOURCE: need a manual to prgoram a sharp er- a440
Programming Manual: http://www.nodevice.com/user_manual/sharp/cash_registers/er-a440.html
Posted on Jan 10, 2010
Anonymous
SOURCE: sharp cd player model xl-hp404,wont play cds code
error code er-c do1
Posted on Dec 26, 2010
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
8helpful
4answers
My sharp cash register ER-A550S stop working
The letter H appears in the screen. The register will not respond. Any idea to what the Letter H means?
2helpful
nuwan.
Jensen hd5112 error 2
CD Changer Error Codes: If problems arise during CD changer operation, the following error codes may appear in the display:
ER-1: No magazine loaded.
ER-2: Problem in the disc loading function.
ER-3: Error in the disc loading function.
ER-4: Error in the disc unloading function.
ER-5: Error in the magazine position.
ER-6: Error in the laser pickup position.
ER-7: Error in the laser focus on the disc.
1helpful
2answers
Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
ER message for CD, Sharp GX-CH150
The optics assembly is having a problem. Either it can not read the disc at all or the disc is not spinning. In any case, the unit will require service. If you can reach the lens, try cleaning it using a cotton swab and alcohol. That may resolve the problem. If not, update this. Please try to see whether or not the disc spins and report that as well.
Thanks,
Dan
Top Sharp Audio Players & Recorders Experts
 Francisco Mauricio...
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
