Question about Rowenta Vacuums
Charger for Rowenta Delta Force vacuum - Rowenta Vacuums
Posted by Marla Carroll on
Hi , I am looking for a Vacuum bag and filter for my Rowenta Vacuum cleaner Model number:RO1767R1 Type: VC20PE3 Ref. number : RO1767R1/4QO-3312R.
Here's one source for the ZR0039 01 paper bag and microfilter for the RO1767R1 compact canister vacuum: https://www.alza.co.uk/rowenta-zr003901-d308208.htm?catid=18850976 . This is a 6 pack of the bags. This vendor also has the Wonder Bag for this model: https://www.alza.co.uk/rowenta-compact-wb305140-wonderbag-d308211.htm?catid=18850976 . I can't find a source for the HEPA filter version (ZR0041 01).
This store has other locations. You can also find the vacuum bags here: https://www.alzashop.com/rowenta-zr003901-d308208.htm?catid=18850976 .
I hope this helps.
Jun 03, 2016 | Rowenta Vacuums
Why does roomba keep docking?
It needs to recharge every time it docks.
I would suggest that you let Roomba run out of the room where it's charger is. Then force it to run until it dies out. Then put it back onto it's charger.. I suspect that it's developed a memory (short) for charging and you need to force it to totally drain down, then charge for a good while. This should force it to develop a "Longer" memory. Works for me anyway.
May 09, 2014 | iRobot Roomba 4210 Bagless Robotic Vacuum
Why roomba clean for 2 minutes then returns to dock?
I suspect the battery is about dead. It keeps coming back for more power.
Run it away from it's charger, force it to run until it dies. Put it onto it's charger and let it charge a long time (Solid green light). Then run it again till it dies and repeat. This will perhaps force the battery to develop a longer memory
Rowenta DE880 replacement cord. Where to order one?
1st, check with your local VACUUM dealers to see if they have one. If not, check online by typing into your search browser (eg- google) "Rowenta DE880 replacement cord" and various stores will come up where to get on online, with a small shipping fee. Compare prices, as not all are the same.
Oct 14, 2013 | Vacuums
Vacuums Logo
104 people viewed this question
Top Rowenta Vacuums Experts
Andrew Taylor
Andrew Taylor
Are you a Rowenta Vacuum Expert? Answer questions, earn points and help others
