Question about Vision Televison & Video
OC White Magnifying Fluorescent Lamp, not lighting?
Model is Vision Lite 2000 by OC White. Maker no longer has parts or repair info. Lamp bulb is good. Variable intensity capable. Has solid state PC board for ballast. Board has no identifying marks. IC on board not identifiable. 40 or so discreet components. Fuse is good. Need any info possible to troubleshoot/repair/replace!! Schematic, IC part number?
Posted by begiese1412 on
4 Related Answers
Anonymous
  • 78 Answers
SOURCE: 1318 inspiron duo core/identify circuit board-fix or replace?"
Contact the manufacturer for support.
Posted on Dec 27, 2009
Anonymous
SOURCE: component failure
i have thes same problem - a capacitor 449 is smoking, and so it appears the red color on my tv is out, and of course i have a burning smell. the model is PCN5425R. Any help is apreciated...
Posted on Apr 19, 2010
chiplevel
rajesh raman
  • 656 Answers
SOURCE: I have an Aurora Data
The IC near the 14.4khz crystel is the clock IC then there is I/O bus ic with if the the board is embanded with lan and audio you will see an ic for each 5then ther is the south bridge and the northbridge the chipset near to the processor is the south bridge and the chip faraway from processor is the norhbridge then there are power ic hexement reiger ic and a bios ic
Posted on Mar 05, 2011
techomecho
  • 430 Answers
SOURCE: Schematic for Behringer PMP3000
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Posted on Feb 12, 2012
WHERE CAN I GET A MANUAL FOR A TENSORVISION MAX FSF402BR FLOOR LAMP WITH NATURAL LIGHT FOR MY LOW VISION. IT HAS NOTHING TO DO WITH A TELEVISION! IT IS A LAMP MADE BY TENSOR CALLED VISION MAX # IS...
I wasn't able to find their web site. The suspected website is for sale and I found that the inventor has died. It may be that it is no longer being made under that name.
This is a link for ordering replacement bulbs.
Tensor Corporation BULB ORDER FORM Free Online Doc
Oct 15, 2014 | Televison & Video
Tip
LCD monitor any brand repairing tips.
LCD monitor symptoms
1. Have power, no screen light display ( CPU 100% working good ).
2. Dim screen light and black screen display.
Solution
a.Open back cover of LCD and then replace the board of fluorescent lamb that's parts defective need to replacement. if that board of fluorescent of your LCD or laptop. no parts available or no replacement parts for that.(other know LCD monitor disposable can't repair because it's very hard to find parts or replacement parts device)
Please see sample picture.
b. Replacement parts.
Cold cathode fluorescent lamp device is use for motorcycle light accessories and desktop PC accessories. it's very easy to find anywhere motorcycle accessories store, hardware store etc. also very low price.
Please see picture below.
This parts, I already use 5 years ago for replacement of LCD fluorescent lamp board(PCB). up to now 100% working good.
I hope this information will be helpful.
Jimmy C. Verdadero
Fixya team
on Aug 08, 2011 | Computers & Internet
A 40 W fluorescent lamp gives out more light than a 4o W filament bulb.explain whether the fluorescent lamp is actually using electrical energy at the same rate as the filament bulb??
The lamps are both using 40 watts of energy, but the fluorescent lamp gives more lumens (visible light measurement) than the incandescent.
Fluorescent gives at least 5000 lumens for 100 watts.
Incandescent gives 1750 lumens for 100 watts.
You can see that if you had a 100 watt incandescent, it would be 1750 and you would only need 35 watts of flourescent.
Gary
Feb 19, 2011 | Vacuums
My screen on my laptop just went all black with a very faint image. what is wrong there, how do i fix it, and what made this happen?
A) What is wrong?;
Your Backlight has gone bad, or the Inverter.
B) How do I fix it?
Replace the Backlight bulb, or the Inverter
C) Backlight bulb's, and Inverters, like everything have a 'lifespan'
This one is at the end of it's. (Stating the Backlight or the Inverter
From here all I can give you is Generic information, since I do not have the laptop manufacturer name, and Model Number. This is on the bottom of the laptop.
1) An LCD screen cannot produce enough light by itself. A Backlight bulb, (Or more than one), is used to emit enough light.
2) A laptop cannot produce enough power to power the LCD screen, and is also used for power to the Backlight.
I'll have to discuss the way the Display Assembly is put together, and name parts in order to explain the following of how to repair. Again, generic information.
1a) The plastic top of the laptop is the Top Cover. There are different names used by different manufacturers.
1b) Looking at the LCD screen with the laptop open, there is a plastic frame that goes around the edges of the LCD screen, and is in Front.
This is the Display Bezel
1c) The LCD screen is behind the Display Bezel. The LCD screen is a composite of layers. The outside layer that faces you is a protective screen.
Around these layers composing the LCD screen, is a metal frame.
One side, (Or both sides) of the metal frame is removed to access the Backlight bulb.
1d) The Backlight bulb is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the fluorescent lamps, (Bulbs) uses in residential, and commercial applications, but on a MUCH smaller scale.
Now to show you generic laptop info on replacing the Backlight bulb for them.
A) http://www.insidemylaptop.com/category/backlight/
B) http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
If I had the laptop manufacturer name, and Model Number, I could try to give you a link to the Service Manual for the laptop. (Free. Usually from the laptop manufacturer)
This way you would have Exact info on how to disassemble your laptop's Display Assembly.
Post in a Comment.
Oct 13, 2010 | Computers & Internet
My monitor is blank. No power when connected to computer. What went wrong It is a benq model
filmorepetty, The "switch-mode-power-supply" has gone into SHUTDOWN mode because it has detected a fault with itself or another circuit. Or it could have just blown a small fuse on the circuit board of the SMPS. Will the pilot lamp light-up? Did it have a clean, bright, crisp, image displayed on the lcd panel the day before? How old or how many total (approx) "ON" hours of use has it seen? Do you know that 98% of lcd monitors use "cold-cathode-fluorescent-lamps" and an accompanying "electronic ballast" circuit to generate the WHITE LIGHT needed for you to see the pretty colors on the LCD Panel?? Same basic lighting technology as the new screw-in socket curlie-Q CFL light bulbs! Only your monitor's lamps are thinner and straight and hung on the rear of the LCD panel. A failure of the ballast circuit could cause SMPS to shutdown. I suggest you visit some other websites for more info on what other owners are doing to try and repair BLACK SCREEN lcd monitor problems. The first place to go would be YOUTUBE and search and view the longer 6-12 minute video clips of "LCD monitor disassembly" and "LCD monitor repair" just FYI and to know what you are dealing with??? Your unit could also have FAILED electrolytic filter capacitors on the SMPS printed circuit board. I'm 12fixlouie Bye for now.
Dec 04, 2009 | Dell E153FP 15" LCD Monitor
Our touch sensitive lamp no longer responds to touch
The sensors do not wear out as such, the fault probably is in the electronics and you should not attempt a repair unless you are suitably qualified as mains voltages are involved.
Nov 22, 2008 | Optics
What are the white balance modes available with the camera?
The following White balance settings are available for the A2: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3-wavelength white fluorescent lamp, 3-wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Televison & Video Logo
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
