Cars & Trucks Logo
Garrett Glashin Posted on Feb 27, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi can the nt650 program and relearn Tpms sensor
Here2HelpYou
Level 3:
Master:
  • Cars & Trucks Master 592 Answers
  • Posted on Feb 28, 2019
Here2HelpYou
Level 3:
Master:
Answers
592
Questions
0
Helped
152555
Points
4122
It has some TPMS functions, not compatible with all vehicles though. I provided a picture from their website showing what manufacturers it's compatible with, and a link to the Foxwell NT-650 Tool on their website with all info and an instructional manual available if you need to check anything else out about your diagnostic scanner. I hope this helps, see pics and included link! Let me know if I've been helpful by clicking the green "helpful" icon. Thank You!
https://www.foxwelltech.com/product/item-376.html
Hi can the nt650 program and relearn Tpms sensor - 989cc717-defd-4057-a35e-ca7e21dc999f-pujhmq5yz2fla13a1caeolco-2-0.jpeg
3 Related Answers
r6_boy
BRIAN
  • 38 Answers
  • Posted on Jun 26, 2012
SOURCE: 2008 Chevy Cobalt TPMS Will Not Reset
I WOULD RUN IT WITH THE TPMS LIGHT ON. IT WILL NOT HURT ANYTHING AT ALL. THE TPMS SYSTEM IS MORE OF ADDED EXTRA FEATURE. I RUN MY CAR WITH ITON BECAUSE IT WILL COST ME ABOUT $600.00 TO REPLACE MY SENSORS. IF THE LIGHT BUGS YOU TO MUCH NAPA SELLS SENSORS ALOT CHEAPER THEN THE DEALER AND ANY LOCAL TIRE SHOP CAN INSTALL THEM AND PROGRAM THEM. HOPE THIS HELPS.
A
Anonymous
  • Posted on Mar 22, 2013
SOURCE: How do you relearn tpms after putting other wheels
In your owners manual
We wouldn't know- even if you
had provided a vehicle
richie46
  • 12962 Answers
  • Posted on Nov 09, 2015
SOURCE: How can I relearn my TPMS?
Dealer does that nonsense. Those tpms systems are one of the worst things ever concocted. And when the battery dies you have to replace the unit and have it reset by dealer. Part alone is usually 100 dollars or more.
Next time it happens in future do NOT replace the tpms sender - carefully open, remove and replace the wax encapsulated battery with another battery. Since you are putting back the SAME unit it does not have to have the car computer recalibrated!!!!!!
Tpms reset on a 2018 altima
No. Relearn has to be done with a TPMS tool or a scan tool with a TPMS add on adapter
1helpful
Got my tired rotated on 2013 ford explorer and now when I make a left hand turn, there is a beeping sound
Does the vehicle have TPMS - tire pressure monitoring system ? Who ever did the job didn't relearn TPMS sensor positions . Take it back .
How do i repair tire pressure sensor
the sensor needs to replaced in the tire. .then programmed to the car via a tpms tool or auto relearn .it is not for the do it yourselfer
Relearn tpms sensors on 2010 suburban
A lot of vehicles can be done thru the radio. You'll need the owners manual to figure out how. I bought one of those $500 tools to do tihs and haven't used it once.
10helpful
2answers
How to reset tire pressure monitor for 2010 chevy equinox
There are two different ways to relearn your Tire Pressure Monitoring System (TPMS). One is with a TPMS scan tool (this is the preferred method) and the other is the manual method (pain in the "you-know what", but requires no special tools or equipment).
To use the manual method, set the parking brake. Enter into TPMS RELEARN using the Driver Information Center (DIC) controls. (SEE Owner's Manual)
When you have successfully entered TPMS RELEARN, the horn will chirp and the left front turn signal will illuminate. Increase or decrease the tire inflation pressure on the left front tire for 8 to 10 seconds. The horn will "chirp", indicating that the left front tire pressure sensor has been relearned and the turn signal at the right front will illuminate. Repeat the process for the right front tire. The horn will chirp and the right rear turn signal will illuminate indicating that the right front tire has been relearned and now you must now repeat the process at the right rear tire. Then you will have to repeat this a fourth time at the left rear. When the left rear tire has been relearned, the horn will sound a "double chirp" indicating that the relearn process has successfully completed.
At this time, turn the ignition switch to the OFF position and adjust all of the tire pressures to the specification printed on the tire certification label inside the drivers door/door pillar area.
7helpful
2answers
2010 Chevrolet Camaro... My TPMS (Tire Pressure Monitoring Sensor) light came on blinking and car is telling me to have it serviced. only 3 of my 4 tires are registering on the system. Is there anyway to...
There is a Technical Service Bulletin (TSB) for your vehicle stating that if the light is blinking and if there are dashes (- -) on only one or two tire pressure readings, then the tire presure monitoring system should be put through a "Relearn" or "matching" process. Then if any of the tire pressure sensors do not respond while relearning, the sensor in that tire should be replaced.
The TPMS matching process is outlined below:
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the engine off.
3. Go to the TPM vehicle information screen on the DIC. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the Driver Information Center screen.
4. Start with the driver side front tire.
5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position.
6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
8. Proceed to the driver side rear tire, and repeat the procedure in Step 5.
9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF.
10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label.
11. Put the valve caps back on the valve stems.
The tires air pressure will not appear on the screen until you start driving the vehicle.
1helpful
Tire trouble light has been on since I had the tires rotated, but there is no problem with the air pressure. Light stays on even though tire pressure is fine.
after rotating tires equipped with tpms, a relearn must be performed so the sensors know where they are. a tpms reprogrammer is required for this.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
