Question about Vehicle Parts & Accessories
Black & Decker JUS350B 350 amp Jump Starter won't charge!
Posted by Carolyn J Clark on
ray gallant
    Top Expert:
  • Vehicle Part... Master
  • 68,645 Answers
USUALLY BECAUSE THE INTERNAL BATTERY HAS DIED
Posted on Feb 27, 2019
2 Related Answers
archaeology
Archaeology
  • 662 Answers
SOURCE: I have a 350 amp Black & Decker jump starter model JUS350B.Why can i not get power across the clamps with a test light
First: the Jump-Starter power switch must be in the "On" poistion, or no voltage will be delivered to the clamps to light your test light.
Second: from the Black & Decker JUS350B owners manual (http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90553956,JUS350B.pdf?_ga=1.9223413.1518759147.1438019791)
This product has a sealed lead acid battery. For maximum battery life, we recommend the Jump-Starter be kept
fully charged at all times. Recharge before first use, immediately after each use, and once a month if not used.
Failure to do this may reduce the battery life dramatically. To check the battery charge status at any time, press
the Battery Charge Level Pushbutton.
When the battery is overly discharged and if the green LED is lit when the charger is plugged in, this indicates the
battery is at a high impedance stage.
In this event, recharge the unit and leave the unit on charge for a period of 24-48hrs before using the unit.
Also, the product reviews by consumers about this (made in China) product are abysmal:
http://www.blackanddecker.com/en-us/product-repository/products/2015/02/01/01/15/jus350b
Posted on Jul 27, 2015
Jul 27, 2015 | JUS350B 350 Amp Jump Starter
Where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Google for an owner's manual. I can't find anything on this jump starter, but first they need to be charged, usually by plugging into a wall socket for 12-24 hours. Then plug into the cigarette lighter for 10 min or so to give the car battery a boost charge.
Dec 04, 2014 | Cars & Trucks
WHERE CAN I FIND A SEL BATTERY CB3-6 6V3AH?
You can try to call Interstate Battery 888-772-3600. I have purchased batteries for my jump packs from them before.
Aug 02, 2014 | BLACK & DECKER VEC012BD - 450 Amp Jump...
MY 350 amp Black and Decker Jump Starter's battery is bad, replacement
They all have the same gray battery in there... but first connect it to the car batery while the car is running for about 30 minutes and see if the battery charges. The little cjharger you have could be not doing a good job...
Apr 19, 2014 | JUMP START SYSTEM
How to charge jump starter
If the battery is real low, It takes about 8 hours to recharge it,
Dec 05, 2012 | Stanley Black & Decker Stanley J5c09 500...
I bought A Stanley 450 jump start & I'm to charge it for 24hr. The 2 red lights are on but the green light is still blinking after 14hr. What does the blinking light mean?
not sure if you found this yet but it is actual made by Baccus Global under the stanley name.
http://www.baccusglobal.com/faq.php
Q: How do I know when my Jump Starter is fully charged?
A: All of the Baccus Global jump starters have a battery status indicator, units can have 2 - 4 LED indicators when all of them illuminate and the green one flashes the unit is fully charged.
Dec 05, 2010 | Black & Decker Jump Start System 450 Amp...
Need instructions on how to use black and decker jump start
Amazon.com: Customer Reviews: Black & Decker VEC010BD Start It 300 Amp ... Instructions note that units are already partially charged before ... Recent discussions in the Black & Decker VEC010BD Start It 300 Amp Jump Starter forum ...amazon.com/Black-Decker-VEC010BD-Start-Starter/.../B000E1HAIK - 235k - Cached
Feb 22, 2009 | Black & Decker Jump Start System 300 Amp...
Vehicle Parts & Accessories Logo
795 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
