Question about RCA R52WM24 52" HDTV Projection Television
Rear projection tv picture is horrible!
I recently got a free big screen tv from a neighbor, it's a older model Sears television. it's a Mag/Sears ptv350 projection TV chassis 626.54521950. the sound on it is amazing, but the picture is horrible! you can see the background and the profile of the people but it's hard to make out much else. the picture is so blurry! i cleaned the screen and had the projectors cleaned, and that made it a little better, but is there anything else i can do to make it actually visible, or is it just a lost cause? also, there is a pink circle in the middle of the picture, which i figured meant the convergence was off, but fixing that didnt solve the problem.. please help!
Posted by luvnjms247 on
ken black
  • 179 Answers
It sounds like the fluid in the crt lens assembly has become contaminated..you can look into the crt lens (with it off) and it will probably look milky. you need to drain the fluid and clean the inside of the lens with denatured alcohol. if it wont clean the the lens needs to be removed, the crt cleaned, and the unit re-assembled and re-filled. this is not the easiest task and you might want to find a local tech to do the job..the fluid is about $30 a bottle and you will need 2-3 bottles. tech labor depends on the area
Posted on Nov 28, 2007
Anonymous
  • 29 Answers
You might have to focus the actual projectors. or, you need new ones because they are worn with age.
Posted on Nov 26, 2007
Anonymous
    Scholar:
  • 76 Answers
You need to reset the convergence. That should fix it if nothing is seriously wrong.
Posted on Mar 08, 2008
I have a old 52 inch sony tv turns on but picture blinks off and on whats wrong
A lot of their older sets (both regular TV sets and big rear projection set had this issue).
In either case it may mean with age the MASTER SCREEN control/s need to be adjusted slightly up---if too dim a picture it will blink.
A model number would tell me what to try.
Models beginning with KP are large projection and ones with KV are regular sets.
Mar 31, 2012 | Televison & Video
I have an older model rca rear projection tv. The problem with the tv is that the picture bends into curve after about 5 minutes after it has been turned on. Please help.
Check the convergence IC's for cold solders, check for leaking capacitors in the area. Check the voltage regulator with a Variac.
Usually these sets just need the 2 big convergence IC's replaced with new ones. Clean all 3 picture tube lenses, mirror and screen. Get the original RCA remote that came with the set and MANUALLY align the convergence.
Rarely the bow on the bottom of the screen is not repairable.
Jul 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
The tv just randomly turns off by itself
Check to see how many times it blinks when turning off and then look for the codes for Sony tv blinks. this will tell you what's wrong. This set is notorious for Shorted tubes.
Feb 27, 2009 | Sony KP-57WS500 57" Rear Projection...
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Sep 16, 2007 | Hitachi 51F510 51" Rear Projection...
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
