Question about Samsung Office Equipment & Supplies
Hi please assist, I have Samsung scx 4623f printer, my issue is when i scan doc it doesnt have an option to save files with pdf format.
Posted by Jabu on
Adorjani Laszlo
  • Samsung Master
  • 1,316 Answers
Download the NAPS2 scan program,this is save in pdf mode.
Posted on Mar 31, 2019
5 Related Answers
HEMANT GROVER
  • 171 Answers
SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
Posted on Oct 26, 2007
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: cannot scan to pdf Deskjet F2100
You have to scan with Adobe Reader in order to scan and save a pdf
Posted on Apr 02, 2008
Anonymous
SOURCE: Scan format - Samsung SCX-4521F to PDF
samsung scx 4521f in black background in more verticle white line in
Posted on Feb 28, 2009
Anonymous
SOURCE: samsung scx-4200 does not give me the option to scan to pdf file
I used a program called SmarThru 4 with the same printer-scanner. Works. Give it a try :).
Posted on Sep 09, 2009
SOURCE: scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
Posted on May 24, 2010
How do I scan to PDF?
w10 has this built in
so what PC is this what OS?
HP now owns samsung printers .
there are only 4 ways,
use w10 print engine way,
use HP way if offered, ask them yet?
or scan to JPG
and use and app to publish jpg to PDF, I use NITRO.
or buy PDF engine driver, to do that.
Samsung SCX-4521F Laser Multifunction Machine Print/Copy/Fax/Scan
Sep 18, 2018 | Samsung Office Equipment & Supplies
Samsung scx-4623f how do i scan multiple page document into one pdf file?
I read the manual and it seems the printer uses links to programs on your pc. So,you could use any pdf program to do that. Scan all your files and then use adobe or any of many programs to "merge" all files into one. Basically a pdf file joiner.
here is one i found for free that i know is good http://www.paologios.com/
Hope this helps :D
Sep 21, 2011 | Office Equipment & Supplies
How can i save from my samsung scx 4216f to pdf format? (windows7) Thanks!
I free software called Cute PDF Writer installs as a virtual printer. Open your scanned document in any application and then select print from the file menu and select the Cute PDF printer.
Jan 30, 2011 | Samsung SCX-4216F All-In-One Laser Printer
I use Ubuntu 10.04 and I want to install my printer Samsung SCX-4623F. What do I have to do? Thank You. Eros.
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
Dec 25, 2010 | Samsung SCX4623F Laser All-in-One Printer
How to reset toner ,Samsung SCX-4623F
we have reset software for scx 4623f printer. www.nakshatraworld.com
May 13, 2010 | Samsung SCX-4300 Monochrome Laser...
Samsung scx-4200 does not give me the option to scan to pdf file
Jun 29, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Feb 20, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Pdf and jpeg format scanning problem in Canon iR2018 copier
Yes,you do have to buy the sent kit.But remember the sent kit Scan to e-mail and not directly to the computer.Your company have to have a mail server to be able to work properly.Adobe have software that you can buy that chance word document to PDF.
Feb 11, 2009 | Canon iR 2016i Black and White Copier
Samsumg SCX 4521F does it pdf?
If you are using the SmartThru software, the otpion to change the scanned format is in the same screen where you state the name of the document and settings for color, resolution, and others.
Be blessed.
Sep 17, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Top Samsung Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
