Question about LG Refrigerators
Water pipe needs replacing on LG american fridge freezer. When I press the dispenser no water is supplied and pipe leaks at bottome of freezer door
Posted by David Ryan on
Jm B
    Problem Solver:
  • 6 Answers
These hoses are common and can be found online or at your local hardware store.
Posted on Apr 16, 2020
David Spradling
    Top Expert:
  • LG Master
  • 11,320 Answers
Get size of hose and get from hardware store or order from manufacturer
5 Related Answers
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Water leaks from tube at the bottom of fridge for water dispenser only
If it is a plastic compression fitting you can tighten each one a little(careful not to tighten them too much cause they can strip out) Use a small crescent wrench with a back up wrench.
Posted on Jan 28, 2008
Anonymous
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Posted on Sep 01, 2008
Anonymous
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
Anonymous
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
Due to the flexible pipe rupture leading water dispenser has a leak at the bottom of the freezer door. Need to replace the hose. How to replace the pipe?
if you go to this site input the model go to the part then they will usually have some instructions on how to put the part in. if not they have chat and 800#
hope this helps
https://www.repairclinic.com/
Jan 04, 2018 | Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge fridge- water dispenser in door wont work yet ice maker does.
There are a few reasons for this. Most common, is the water filter. After a period of time(literage usage) the filter eventually blocks up.Flow will not continue until a new one is installed. On occasion, the water line in the freezer ices up, but doesn't often happen. If so, you will need to defrost freezer until pipe is no longer iced up(set freezer to about -20 degrees celsius).or very possible, water solenoid at the back of the fridge has gone faulty.You will need help with this check,There will be 2 valves. Very possibly it will be the RHS one at the back. Switch water supply off at the back then go to the water solenoids at the back of the fridge.and disconnect the one pipe on the solenoid that leads into the fridge. Open fridge water tap again and ask member to quickly press water dispenser lever.Note if water squirts out for that brief period.. If not, reconnect pipe again then do the same disconnection to the second solenoid. If no water comes out then,(make sure water is open), then the water valve needs to be replaced.
Oct 04, 2009 | GE Refrigerators
Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
95 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
