Question about Vizio P2 42 in. HD-Ready Plasma Television
On and off and on again
My television was turning on and after a while it would turn off for a few seconds, the power light would trun yellow and then turn back on to green. Now it won't turn on at all, but the power light is still on yellow. I tried unplugging it overnight, thinking it might need to reset. I would appreciate any insight. hi i own a Vizio P50HDM when i turn on my tv the orange light turns green and the tv will click like it wants to turn on but it doesnt. no picutre no sound but the light either blinks from orange to green or itll stay in one color... what can this be help me please.
Posted by waltgon on
  • 3 more comments
  • Anonymous Dec 14, 2007
    Same problem here..... TV won't turn on. Tried to reset, but no luck. I've nly had the TV for a year.....
  • DJMcD Dec 19, 2007
    My Vizio P50HDTV also goes off and on again on its own. I plan to contact Vizio. Any known solutions? Thanks.
  • kski Dec 21, 2007
    Have the same problem, went inside and all voltage levels look fine. Was working fine for about a month and now unusable...
  • Anonymous Aug 02, 2008
    i turned on tv last night and there is no sound and no image on the screen. light is green all the time and i can't turn it off.
  • gathira Aug 02, 2008
    i have a vizio and turned it on last night. there was no sound or image on screen. now i can't turn it off.
Anonymous
Hi i had the the same promblem where the screen and sound went out and the light still lit. have someone or do it yourself, check the ceramic fuses on the y sys board which is the large board on the right looking at it from the back of the tv. i replaced mine becasue that board was not working. if not it could be the power supply. i got the board on ebay and replaced it myself saved about 400 dollars.
Posted on Dec 24, 2007
Adolph Smith
  • 137 Answers
You have a power supply problem, it is in standby . Replace powersupply board or fix it.
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
The power light is constantly blinking in yellow. before this happened the yellow light was on without blinking I turned it off, once I turned it back on the light turned green but the screen...
try unplugging your t.v for 10-20 seconds. plug it back in. if your power light continues to flash your t.v is the issue. you should be able to google your issue or check your owners manual about the problem. unplugging the t.v is the last ditch effort. Good Luck!
May 18, 2011 | Akai LCT2715 27 in. LCD Television
Turn on ps3, light truns green for a second then turn red with a beeping noise?
I had this problem not a few months ago. It is the beginning of the yellow light of death syndrome. Sony can repair it if it is in warranty, or there are independent chains that also do repairs. The price to repair mine (replacing the optical drive) was $130.
Mar 12, 2011 | Sony Playstation 3 (PS3) Console
I have a 42" Maxent plasma tv. When turned on,
one or your tv mainboard was crashed, change it with new one
Jan 18, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
I dont't have a solution but I now have the same problem. Very frustrating. Vizio suggested the "cold boot" by unplugging but this seems to have made it worse. Like the product but not this!
Feb 15, 2007 | Vizio L32 32 in. LCD HDTV
Vizio P2 42 in. HD-Ready Plasma Television Logo
388 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
