Test that lights turn on when switch is in ON position. Then turn knob to "TIMER" and set both the time you want the lights to come on then the time for off. Leave knob at "TIMER".
https://www.smarthome-products.com/productspecs/Malibu/8100-0300-01-Manual.pdf
TIMER - The power pack turns on when the clock reaches the TIMED ON time. The power pack will turn off when the clock reaches the TIMED OFF time.
This mode will turn the power pack on and off at the same times everyday regardless of how light or dark it is. The power pack and lights will be on from the TIME ON time to the TIMED OFF time. To set the TIMED ON clock, the knob needs to be turned to TIMER, then hold down the TIMED ON button while pressing either the or button. Pressing while holding down the TIMED ON button will advance the displayed time. Pressing while holding down the TIMED ON button will decrease the time displayed. Holding the or button down for several seconds will speed up the change in the display. Releasing the TIMED ON button will set the time. Note the AM/PM LED indicators to get the correct time of day.
To set the TIMED OFF clock, the knob needs to be turned to TIMER, then hold down the TIMED OFF button while pressing either the or button. Pressing while holding down the TIMED OFF button will advance the displayed time. Pressing while holding down the TIMED OFF button will decrease the time displayed. Holding the or button down for several seconds will speed up the change in the display. Releasing the TIMED OFF button will set the time. Note the AM/PM LED indicators to get the correct time of day
SOURCE: Malibu landscape transformer
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
SOURCE: How do you set the timer on Malibu 300 watt
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Malibu 600 watt transformer timer not working.
The timer motor is probably bad. Unfortunately, Malibu transformers have very few user servicable parts :-( , and the timer motor isn't one of them. One cannot even access the internal connections. If you recently purchased the transformer, return it to the store. If the transformer is less than 5 years old, it's still under warranty. In that case visit the Malibu website for instuctions.
Testimonial: "Thanks, very helpful info."
SOURCE: Malibu 300-Watt Low Voltage Transformer ML300RTW Not Functioning
My power went off at my house. After it came by on how do I reset the transformer to come on automatically?
