Question about Camping, Backpacking & Hiking
Ranico reading light
The light will not recharge
Posted by Nancy Macri on
Battery is not working more than two weeks suddenly on speedo meter it show read light on battery and I recharged it than it stop again what can I do?
Your Alternator is no good, that light is not to tell you the battery is bad, it is to tell you the battery is not getting charged. Do you read the owner's manual?
May 13, 2016 | Cars & Trucks
I need a repair manual for a rechargable lantern Linross CH 8858
GO TO GOOGLE TYPE IN INSTRUCTION MANUEL FOR RECHARGABLE LINCROSS CH8858 FLASHLIGHT.YOU SHOULD BE ABLE TO DOWN LOAD OR READ IN PDF.
Aug 14, 2014 | Camping, Backpacking & Hiking
Red light wont stop flashing.
Recharge it. Is this in the house without any laser to activate the light/
If so - read the instruction again or seek a service center.
Sep 01, 2013 | Robotoolz 3 - Beam Level and Plumb Laser,...
MTG 900 SAYING "CHARGE" AND I'VE BEEN PUTTING
I am assuming you are reading the battery charge correctly. If so you need a new rechargable battery. Special battery so it is a little expensive. Make sure the person knows it is a "rechargable battery" you want. A regular battery will not work properly or recharge.
Nov 02, 2011 | Casio Atomic-Solar MTG900 Watch
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
My solar lights will not stay on they will blink and go off.I live in Florida SUNSHINE most of time. These are from Home Depot and are Hampton Bay mfg.
... and they are how old???
In my experience, where I live to the North of you, where I work in a camping resort, where our seasonal campers make use of the same devices from the same supply and source), I have found the batteries in these devices are good for NO MORE than two seasons with little exception.
You might have other troubles, like the day-lite sensor is cloudy or being impacted by some other light source or the panels are cloudy and will not charge the battery fully. Read on please.
The way these things work, generally speaking, the solar panel part of your light actually recharges a rechargable battery in the battery pack. These batteries take a beating - fully recharging and fully discharging EVERY DAY. You can probably replace these batteries with new RECHARGABLE batteries to extend the useful life of your lights. Did I mention the lights are always subject to the full heat of your beautiful sunny days as well as the full fury of your dreadful rainy season? BTW, we visit often and love Florida.
I hope this information helps you.
Thanks for using FixYa.com
please vote
thanks
a
Dec 05, 2009 | Washing Machines
Meter is consistently a half to a full stop off
I've known this problem to occur if the wrong kind of CR123/CR123A lithium battery is used. They come as rechargeable and dry cell (i.e. non-rechargeable) versions. For sensitive devices like yours the difference is important as the internal resistance of the rechargeables is lower which affects the voltage characteristics.This meter is designed only for the dry cell version: see page 34 of the user manual, although the instructions don't make this fact clear enough IMHO. The reason for using the dry cell version is that the output voltage remains constant until the battery is nearly exhausted, but the rechargeable version starts at a slightly higher than nominally rated voltage and drifts down as the battery discharges. This means that you only get a truly accurate reading with a dry cell battery. There is no user adjustment to recalibrate the meter but you can use a different ISO rating to compensate or use the exposure compensation settings.
Apr 19, 2009 | Sekonic L-358 Flash Master Light Meter
I have a Zen Creative 4 GB which I recharge by plugging into our computer. The blue light comes on and fades as mentioned it would when recharging. The problem is that is looses its charge after approx a...
Hi
I thought you were going to give me an answer to my question. I am sadly disappointed after reading your 'answer' that I have been eagerly waiting on all day.
Aug 18, 2008 | Audio Players & Recorders
Camping, Backpacking & Hiking Logo
179 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
